descriptor setup
Special, common to Samsung, function for altering usb descriptor's
idVendor and idProduct has been added.
For compatibility reasons (Win vs Linux) the THOR idProduct must be
different than the one for DFU/UMS.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Lukasz Majewski <l.majewski@samsung.com>
I2C framework
New I2C framework, introduced after v2013.07 final release, imposed I2C
code adjustment for some Samsung boards - namely Trats, GONI and Universal_c210.
Those boards were using schematic based I2C enumeration (I2C_5, I2C_9).
However, new I2C framework imposes usage of logical I2C adapters numbering
(e.g. I2C_0, I2C_1, etc).
Additionally, I2C_GET_* macros were replaced with i2c_*_bus_num() functions.
Trats board gained definition of second soft I2C adapter.
[trini: Fixup common/cmd_io.c]
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused.
It is renamed to exynos-uboot-spl.lds
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Support for multiple soft I2C buses.
Multibus I2C support is achieved by defining get_multi_{sda|scl}_pin
functions to switch between multiple "soft" I2C buses.
Common definition of I2C_X I2C buses is provided at <i2c.h>.
TEST HW:
Samsung's Exynos4210 evt.0.1 - Trats development board
Acked-by: Heiko Schocher <hs@denx.de>
