path: root/board/samsung/common
2015-11-02samsung: clean up checkpatch issuesMinkyu Kang
This patch will fix these checkpatch issues. CHECK: Alignment should match open parenthesis + printf("Enter: %s %s\n", mode_name[mode][0], + mode_info[mode]); CHECK: Alignment should match open parenthesis + lcd_printf("\n\n\t%s %s\n", mode_name[mode][0], + mode_info[mode]); CHECK: Alignment should match open parenthesis + lcd_printf("\t%s %s - %s\n\n", selection[i], + mode_name[i][0], Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02exynos5-dt-types: add board detection for Odroid XU3/XU3L/XU4.Przemyslaw Marczak
This commit adds additional file with implementation of board detection code for Odroid-XU3/XU4. The detection depends on compatible found in fdt: - "samsung,exynos5" - uses Exynos5 generic code - "samsung,odroidxu3" - try detect XU3 revision There are few revisions of Odroid XU3/XU4, each can be detected by checking the value of channel 9 of built-in ADC: Rev ADC Board 0.1 0 XU3 0.1 0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT 0.3 1280 XU4 0.1 The detection code depends on the ADC+10% value. Implementation of functions: - set_board_type() - read ADC and set type - get_board_rev() - returns board revision: 1..3 - get_board_type() - returns board type string Additional functions with return values of bool: - board_is_generic() - true if found compatible "samsung,exynos5" but not "samsung,odroidxu3" - board_is_odroidxu3() - true if found compatible "samsung,odroidxu3" and one of XU3 revision. - board_is_odroidxu4() - true if found compatible "samsung,odroidxu3" and XU4 revision. After I2C controller init, the get_board_type() can check if the XU3 board is a "Lite" variant, by probing chip 0x40 on I2C0 (INA231 - exists only on non-lite). This is useful for setting fdt file name at misc_init_r(). Enabled configs: - CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - CONFIG_ODROID_REV_AIN - CONFIG_REVISION_TAG - CONFIG_BOARD_TYPES Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02samsung: board/misc: check returned pointer for get_board_type() callsPrzemyslaw Marczak
The function get_board_type() is called in two places by common code, but the returned pointer was never check. This commit adds checking the returned pointer, before use it. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-31exynos: Rise ARM voltage to 1.1V for chained bootloadersMisha Komarovskiy
If board uses downstream Chrome OS U-Boot as first stage bootloader and upstream version is chained second stage, 1.1V is minimum voltage borderline. Signed-off-by: Misha Komarovskiy <zombah@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Remove unneeded device tree control #ifdefsSimon Glass
Since device tree is used for all exynos5 boards, we can remove the #ifdef and reduce confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Add common board code for exynos5 boards that use device treeSimon Glass
Some boards use device tree for almost all board-specific configuration. They therefore do not need their own separate board code, but can all use the same version. Add a common version of the board code. It uses the PMIC, regulator and video bridge uclasses. This will support smdk5250, smdk5420, snow, spring, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-06-18fix: samsung: common: autoboot.cmd: Correct itbcfg definitionŁukasz Majewski
This fix is necessary to avoid booting the default ITB configuration. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-06-08samsung: common: add example boot scriptsPrzemyslaw Marczak
This commit adds example scripts of boot.scr: - bootzimg.cmd - check if dtb exists and boot zImage - autoboot.cmd - check which image exists: Image.itb, zImage or uImage and optionally load fdt file for u/zImage The blank spaces are added to improve readability and can be removed before use mkimage. Required U-Boot environment variables: $boardname, $fdtfile, $console, $mmcbootdev, $mmcbootpart, $mmcrootdev, $mmcrootpart, $rootfstype. Making boot.scr from file.cmd: mkimage -C none -A arm -T script -d file.cmd boot.scr The Odroid XU3 default environment is ready for those boot scripts and the right script can be loaded by DFU. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2015-06-08smdk5420: board: add functions required to enable USB DWC3Joonyoung Shim
This commit adds implementation of function calls: - usb_gadget_handle_interrupts() - board_usb_init() Which allow enable USB DWC3 gadget for this board. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Inha Song <ideal.song@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2015-05-14odroid: enable driver model pmic/regulator API and MAX77686 driversPrzemyslaw Marczak
This change enables the configs required to init and setup max77686 regulator driver, using the new driver model pmic and regulator API. And also changes the old pmic framework calls to the new ones. This commits enables: - CONFIG_ERRNO_STR - CONFIG_DM_PMIC - CONFIG_DM_PMIC_CMD - CONFIG_DM_PMIC_MAX77686 - CONFIG_DM_REGULATOR - CONFIG_DM_REGULATOR_CMD - CONFIG_DM_REGULATOR_MAX77686 And removes the unused: - CONFIG_DM_I2C_COMPAT - CONFIG_POWER - CONFIG_POWER_I2C - CONFIG_POWER_MAX77686 Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: board:samsung: power_init_board: add requirement of CONFIG_DM_PMICPrzemyslaw Marczak
In the power_init_board function call, regulator driver init is called, so before compile, make sure that any power framework is defined. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18exynos: cros_ec: Drop unnecessary initSimon Glass
Since driver model will probe the EC when it is first used, we do not need to init it explicitly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-14usb: board: samsung: Add default board_usb_cleanup() definition for Exynos SoCsLukasz Majewski
This definition is necessary for Exynos based boards to work properly. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-03-04board: samsung: reserve memory for the secure firmwarePrzemyslaw Marczak
Since more than one board requires memory reservation for the secure firmware, the reservation code can be made in a common code. Now, to reserve some part of the the last bank, board config should define: - CONFIG_TZSW_RESERVED_DRAM - len in bytes - CONFIG_NR_DRAM_BANKS - number of memory banks Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04samsung: board: fix: Define loop iterator as an unsigned int to suppress gcc ↵Łukasz Majewski
4.8 warning This patch suppress following warning: board/samsung/common/board.c:95:32: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations] addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); ^ board/samsung/common/board.c:94:2: note: containing loop about possible signed integer overflow at gcc 4.8.2 (odroid board) Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-25dfu: samsung: move call to set_dfu_alt_info() to dfu common codePrzemyslaw Marczak
This common call can be used for setting proper entities based on dfu command arguments. The config: CONFIG_SET_DFU_ALT_INFO, was used only for few configs, and now it is common. The board file should implement: - set_dfu_alt_info() function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)]
2015-02-13samsung: board: support eMMC reset using DTJoonyoung Shim
Some exynos boards require special handling of nRESET_OUT line for eMMC memory to perform complete reboot e.g. Odroid X2/U3/XU3 boards. This will support eMMC reset using DT from reset_misc of samsung common board file. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-25samsung: board: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-22dm: exynos: Convert SPI to driver modelSimon Glass
Move the exynos SPI driver over to driver model. This removes quite a bit of boilerplate from the driver, although it adds some for driver model. A few device tree additions are needed to make the SPI flash available. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: exynos: Make sure that GPIOs are requestedSimon Glass
With driver model GPIOs must be requested before use. Make sure this is done correctly. (Note that the soft SPI part of universal is omitted, since this driver is about to be replaced with a driver-model-aware version) Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Tidy up GPIO headersSimon Glass
The wrong header is being included, thus requiring the code to re-declare the generic GPIO interface in each GPIO header. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05exynos_fb: Remove usage of static definesAjay Kumar
Previously, we used to statically assign values for vl_col, vl_row and vl_bpix using #defines like LCD_XRES, LCD_YRES and LCD_COLOR16. Introducing the function exynos_lcd_early_init() would take care of this assignment on the fly by parsing FIMD DT properties, thereby allowing us to remove LCD_XRES and LCD_YRES from the main config file. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05samsung: misc: use board specific functions to set env board infoPrzemyslaw Marczak
This change adds setup of environmental board info using get_board_name() and get_board_type() functions for config CONFIG_BOARD_TYPES. This is useful in case of running many boards with just one config. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05samsung: board: enable support of multiple board typesPrzemyslaw Marczak
This change adds declaration of functions: - set_board_type() - called at board_early_init_f() - get_board_type() - called at checkboard() For supporting multiple board types in a one config - it is welcome to display the current board model. This is what get_board_type() should return. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05samsung:board: misc_init_r: call set_dfu_alt_info()Przemyslaw Marczak
This change enable automatic setting of dfu alt info on every boot. This is useful in case of booting one u-boot binary from multiple media. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05samsung: misc: add function for setting $dfu_alt_infoPrzemyslaw Marczak
This change introduces new common function: - set_dfu_alt_info() - put dfu system and bootloader setting into $dfu_alt_info. functions declaration: - char *get_dfu_alt_system(void) - char *get_dfu_alt_boot(void) - void set_dfu_alt_info(void) and new config: - CONFIG_SET_DFU_ALT_INFO This function can be used for auto setting dfu configuration on boot. Such feature is useful for multi board support by one u-boot binary. Each board should define two functions: - get_dfu_alt_system() - get_dfu_alt_boot() Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05board:samsung: check the boot device and init the right mmc driver.Przemyslaw Marczak
It is possible to boot device using a micro SD or eMMC slots. In this situation, boot device should be registered as a block device 0 in the MMC framework, because CONFIG_SYS_MMC_ENV_DEV is usually set to "0" in the most config cases. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05samsung: misc: fix soc revision setting in the set_board_info()Przemyslaw Marczak
The byte order of soc revision was inverted, now it is fixed. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-30arm: Add missing .vectors section to linker scriptsBenoît Thébaudeau
Commit 41623c9 'arm: move exception handling out of start.S files' missed some linker scripts. Hence, some boards no longer had exception handling linked since this commit. Restore the original behavior by adding the .vectors section to these linker scripts. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-20samsung: dfu: Provide correct Vendor and Product IDs for UMS gadgetLukasz Majewski
It is necessary to provide the same Vendor and Product IDs as the one in the original Linux kernel code. Without this change the USB mass storage gadget is not working with Windows7. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-06-02Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-16ARM: exynos: board: change the mmc/sd init sequenceJaehoon Chung
Exynos4 can be used the dwmmc controller for eMMC. Then it needs to check dwmmc_init() at first. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-15Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-08ums: move IO support code to common locationStephen Warren
There's nothing Samsung-/board-specfic about the implementation of ums_init(). Move the code into cmd_usb_mass_storage.c, so that it can be shared by any user of that command. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-05-08ums: remove ums_disk_init()Stephen Warren
Now that ums_disk_init() is so simple, there's no need for it to be a separate function. Instead, just add it to the tail end of ums_init(). Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-05-08ums: remove error-checking of MMC device sizeStephen Warren
There's no reason to believe that an MMC device will incorrectly report its capacity. Remove error checking of this value from ums_disk_init() to simplify it. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-05-08ums: remove UMS_{NUM,START}_SECTORS + UMS_START_SECTORStephen Warren
These values aren't set anywhere at present, and hence have no effect. The concept of a single global offset/number of sectors to expose through USB Mass Storage doesn't even make sense in the face of multiple storage devices. Remove these defines to simplify the code. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-05-08ums: support block devices not MMC devicesStephen Warren
The USB Mass Storage function could equally well support a SATA device as support an MMC device. Update struct ums to contain a block device descriptor, not an MMC device descriptor. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-05-07samsung: misc: remove download mode info screenPrzemyslaw Marczak
This change removes LCD menu download mode info screen. Now key press timeout is checked in function download_menu() and menu options are displayed directly after PWR + VOLUP keys. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-07samsung: misc: menu: increase delay in menu main loopPrzemyslaw Marczak
Increase menu loop delay to 200 ms helps choose the right menu option by user. Before this, each time key was pressed the current menu option was changed few times. Now it changes only once and also changes few times if key is pressed for a longer time. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-07samsung: misc: add env default option to lcd menuInha Song
This change allows reset device environment to default without using u-boot console, which is useful for system developers. Signed-off-by: Inha Song <ideal.song@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-07samsung: misc: add gpt restore option to lcd menuPrzemyslaw Marczak
This menu option allows restore gpt. This is usefull and no needs access to the u-boot console. For proper operation: - each partition uuid should be set in environment or - CONFIG_RANDOM_UUID should be defined for automatically uuid setting After operation success device is going to be reset. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-07samsung: misc: allows using environmental macros as args in menu commandsPrzemyslaw Marczak
Function cmd_process() runs commands with directly given list of arguments but it doesn't expand given environmental variables names as macros. Command "gpt" as one of arguments expects expanded macro e.g. $partitions so it needs to be called by function run_command(). Changes: - extend array mode_name by lower case commands names - used by find_cmd() - put each command arguments into one string - used by run_command() - use run_command() instead of cmd_process() Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-05ums: always initialize mmc before ums_disk_init()Mateusz Zalega
In cases when MMC hadn't been initialized before, ie. by the user or other subsystem, it was still uninitialized while UMS media capacity check, leading to broken ums command. UMS has to initialize resources it uses. Tested on Samsung Goni. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Tested-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-03-25Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Trivial merge conflict, needed to manually remove local_info as per commit 41364f0f. Conflicts: board/samsung/common/board.c
2014-03-17cros_ec: Move EC interface into common libraryVadim Bendebury
Add a common library for obtaining access to the Chrome OS EC. This is used by boards which need to talk to the EC. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Tested-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-12arm:exynos: enable sdhci and misc_init to common boardPiotr Wilczek
This patch enables sdhci initialisation and misc_init_r in common board file for all exynos 4 based boards. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
