path: root/board/sagem/f@st1704
2017-05-31MIPS: add BMIPS Sagem F@ST1704 boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
