path: root/board/sacsng
2007-07-04Remove obsolete mpc824x linker scriptsGrant Likely
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-09-15* Patches by Jon Diekema, 15 Sep 2003:wdenk
- add description for missing CFG_CMD_* entries in the README file - sacsng tweaks: include/configs/sacsng.h: + Support extra bootp options like: 2nd DNS and send hostname + Enabling ping and irq command + Adding defines for a bunch of misc configrabled options (patches for these options will be coming) + Adding watchdog support, but it isn't enabled yet. board/sacsng/sacsng.c: + Suppressing unneeded output when the quiet environment is non-zero. + show_boot_progress() now accepts any negative number as a failure code. + show_boot_progress() flashes the error code 5 times, and then resets the board to retry the boot from the top * Patch by Gleb Natapov, 14 Sep 2003: enable watchdog support for all MPC824x boards that have a watchdog
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2002-11-11* Patch by Andreas Oberritter, 09 Nov 2002:wdenk
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration
2002-09-27Initial revisionwdenk
2002-05-23Initial revisionwdenk
2002-03-25Initial revisionwdenk
2002-03-14Initial revisionwdenk
