path: root/board/rsdproto
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-17Fix the i2c frequency and default address in rsdproto boardLuotao Fu
rsdproto board support has wrong I2C frequency and wrong return value handling. Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
2007-11-17powerpc: Backout relocation changes.Grant Likely
Ugh. I *hate* to back this change out, but these compiler flags don't work for relocation on all versions of GCC. I've not been able to reproduce the environment in my setup (and hence, not been able to find a combination that *does* work), so I've got no choice but to go back to the old gcc flags and linker script. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-04Correct fixup relocation for mpc8260Grant Likely
2007-07-04Consolidate mpc8260 linker scriptsGrant Likely
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2001-04-28Initial revisionwdenk
2001-01-11Initial revisionwdenk
