Enough time has passed since this board was moved to Orphan. Remove.
- Remove board/rsdproto/*
- Remove include/configs/rsdproto.h
- Move the entry from boards.cfg to doc/README.scrapyard
[trini: Fixup common/cmd_io.c]
In the process, also remove backward-compatiblity macros BIN_TO_BCD and
BCD_TO_BIN and update the sole board using them to use the new bin2bcd
and bcd2bin instead
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Acked-by: Detlev Zundel <dzu@denx.de>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
