path: root/board/rpxsuper
2011-11-07board/rpxsuper/flash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: flash.c: In function 'flash_init': flash.c:52:19: warning: variable 'size' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07board/rpxsuper/flash.c: minimal CodingStyle cleanupWolfgang Denk
Really minimal and local, just good enough to make checkpatch not complain about the changes in the following commit. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-07-04Remove obsolete mpc824x linker scriptsGrant Likely
2001-04-28Initial revisionwdenk
2001-04-23Initial revisionwdenk
