path: root/board/ronetix
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-01-17common: Move RAM-sizing functions to init.hSimon Glass
These functions relate to memory init so move them into the init header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02Move strtomhz() to vsprintf.hSimon Glass
At present this function sits in its own file but it does not really justify it. There are similar string functions in vsprintf.h, so move it there. Also add the missing function comment. Use the vsprintf.h include file explicitly where needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Drop global inclusion of status_led.hSimon Glass
This is only used by a few files so it should not be in the common header. Move it out. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-07-12board: pm9263: Convert to CONFIG_DM_USB and CONFIG_DM_VIDEOIlko Iliev
Convert the board to support the USB and video driver model and remove the unnecessary code.
2019-07-12board: pm9261: Convert to CONFIG_DM_USB and CONFIG_DM_VIDEOIlko Iliev
2019-04-09board: pm9g45: Migrate to CONFIG_DMIlko Iliev
Migrate the following options to CONFIG_DM: CONFIG_DM_GPIO CONFIG_DM_MMC CONFIG_DM_ETH CONFIG_DM_SERIAL CONFIG_DM_USB Signed-off-by: Ilko Iliev <iliev@ronetix.at>
2017-10-16Drop CONFIG_HAS_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-08-04board: pm9261: Update to support DT and DMWenyou.Yang@microchip.com
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-04board: pm9263: Update to support DT and DMWenyou.Yang@microchip.com
Update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11board: ronetix: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-02-18board: atmel: clean up peripheral clock codeWenyou Yang
Due to introducing the new peripheral clock handle functions, use these functions to reduce duplicated code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> [Rebased on current master, fixup for at91rm9200ek] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-11cosmetic: board: pm9263 rewrite old style stuct initJeroen Hofstee
this prevent some warnings when compiling with clang cc: Stelian Pop <stelian@popies.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-11cosmetic: atmel: replace old style struct initJeroen Hofstee
This prevents some warnings when building with clang. cc:: andreas.devel@googlemail.com Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-09at91: switch coloured LED to gpio APIAndreas Bießmann
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2011-12-12pm9g45: init serial console before relocationAsen Dimov
The early messages can be seen on the debug console. Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
2011-12-12pm9261: init serial console before relocationAsen Dimov
2011-12-12pm9263: init serial console before relocationAsen Dimov
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-23Merge branch 'hs@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'hs@denx.de' of git://git.denx.de/u-boot-staging: drivers/net/dnet.c: Fix GCC 4.6 warnings board/xaeniax/flash.c: Fix GCC 4.6 warnings net/bootp.c: Fix GCC 4.6 warning common/cmd_bootm.c: Fix GCC 4.6 warnings board/mx1ads/mx1ads.c: Fix GCC 4.6 warning board/mx1ads/syncflash.c: Fix GCC 4.6 warnings board/lubbock/flash.c: Fix GCC 4.6 warnings drivers/net/cs8900.c: Fix GCC 4.6 warning arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings drivers/net/lan91c96.c: Fix GCC 4.6 warning board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
2011-11-23board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: pm9263.c: In function 'pm9263_lcd_hw_psram_init': pm9263.c:167:20: warning: variable 'x' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-08ARM: define CONFIG_MACH_TYPE for all ronetix boardsAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03make pm9263 buildable for v2011.06 releaseAsen Dimov
2011-09-03pm9261: compiles with the AT91 reworked schemeAsen Dimov
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-12-16pm9261: ARM relocation supportAsen Dimov
Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-12-16pm9263: ARM relocation supportAsen Dimov
2010-12-16pm9g45: ARM relocation supportAsen Dimov
2010-10-06pm9g45: fix compile warningWolfgang Denk
Fix warning: pm9g45.c: In function 'pm9g45_macb_hw_init': pm9g45.c:99: warning: unused variable 'pio' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ilko Iliev <iliev@ronetix.at>
2010-10-06pm9263: fix compile warningWolfgang Denk
Fix warning: pm9263.c: In function 'pm9263_macb_hw_init': pm9263.c:99: warning: unused variable 'pio' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ilko Iliev <iliev@ronetix.at>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-06add new board pm9g45Asen Dimov
Add the new board PM9G45 from Ronetix GmbH. * AT91SAM9G45 MCU at 400Mhz. * 128MB DDR2 SDRAM * 256MB NAND * 10/100 MBits Ethernet DP83848 * Serial number chip DS2401 The board is made as SODIMM200 module. For more info www.ronatix.at or info@ronetix.at. Signed-off-by: Asen Dimov <dimov@ronetix.at>
