path: root/board/ronetix
2011-12-12pm9g45: init serial console before relocationAsen Dimov
The early messages can be seen on the debug console. Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
2011-12-12pm9261: init serial console before relocationAsen Dimov
2011-12-12pm9263: init serial console before relocationAsen Dimov
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-23Merge branch 'hs@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'hs@denx.de' of git://git.denx.de/u-boot-staging: drivers/net/dnet.c: Fix GCC 4.6 warnings board/xaeniax/flash.c: Fix GCC 4.6 warnings net/bootp.c: Fix GCC 4.6 warning common/cmd_bootm.c: Fix GCC 4.6 warnings board/mx1ads/mx1ads.c: Fix GCC 4.6 warning board/mx1ads/syncflash.c: Fix GCC 4.6 warnings board/lubbock/flash.c: Fix GCC 4.6 warnings drivers/net/cs8900.c: Fix GCC 4.6 warning arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings drivers/net/lan91c96.c: Fix GCC 4.6 warning board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
2011-11-23board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: pm9263.c: In function 'pm9263_lcd_hw_psram_init': pm9263.c:167:20: warning: variable 'x' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-08ARM: define CONFIG_MACH_TYPE for all ronetix boardsAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03make pm9263 buildable for v2011.06 releaseAsen Dimov
2011-09-03pm9261: compiles with the AT91 reworked schemeAsen Dimov
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-12-16pm9261: ARM relocation supportAsen Dimov
Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-12-16pm9263: ARM relocation supportAsen Dimov
2010-12-16pm9g45: ARM relocation supportAsen Dimov
2010-10-06pm9g45: fix compile warningWolfgang Denk
Fix warning: pm9g45.c: In function 'pm9g45_macb_hw_init': pm9g45.c:99: warning: unused variable 'pio' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ilko Iliev <iliev@ronetix.at>
2010-10-06pm9263: fix compile warningWolfgang Denk
Fix warning: pm9263.c: In function 'pm9263_macb_hw_init': pm9263.c:99: warning: unused variable 'pio' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ilko Iliev <iliev@ronetix.at>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-06add new board pm9g45Asen Dimov
Add the new board PM9G45 from Ronetix GmbH. * AT91SAM9G45 MCU at 400Mhz. * 128MB DDR2 SDRAM * 256MB NAND * 10/100 MBits Ethernet DP83848 * Serial number chip DS2401 The board is made as SODIMM200 module. For more info www.ronatix.at or info@ronetix.at. Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-04-30pm9263 converted to at91 soc accessAsen Dimov
2010-04-30pm9261 converted to at91 soc accessAsen Dimov
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2009-09-05DM9000 init for pm9261Ilko Iliev
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
2009-06-21at91: unify nor boot supportJean-Christophe PLAGNIOL-VILLARD
the lowlevel init sequence is the same so unify it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-21at91: add support for the PM9261 board of Ronetix GmbHIlko Iliev
The PM9261 board is based on the AT91SAM9261-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9261.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-21pm9263: use macro instead of hardcode value for the lowlevel_initJean-Christophe PLAGNIOL-VILLARD
optimize a few the RAM init Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-21pm9263: lowlevel init updateJean-Christophe PLAGNIOL-VILLARD
move PSRAM init to pm9263.c this will allow us after to make the nor lowlevel_init generic Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12at91: move cpu info print to cpuJean-Christophe PLAGNIOL-VILLARD
2009-04-16at91: add support for the PM9263 board of Ronetix GmbHIlko Iliev
The PM9263 board is based on the AT91SAM9263-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9263.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
