Update the MAINTAINERS file to include the devicetree for the
rk3568-evb1-v10 board.
Also update Rockchip board docs to include information on building
RK3568 based devices.
Signed-off-by: Chris Morgan <macromorgan@hotmail.com>
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Radxa Compute Module 3(CM3) IO board an application board from Radxa
and is compatible with Raspberry Pi CM4 IO form factor.
Radxa CM3 needs to mount on top of this IO board in order to create
complete Radxa CM3 IO board platform.
Add support for Radxa CM3 IO Board defconfig and -u-boot.dtsi
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add Radxa ROCK 3 Model A support. sync rk3308-rock-pi-s.dts from
Linux 6.2.0-rc7.
ROCK Pi S is RK3308 based SBC from radxa.com. ROCK Pi S has a,
- 256MB/512MB DDR3 RAM
- SD, NAND flash (optional on board 1/2/4/8Gb)
- 100MB ethernet, PoE (optional)
- Onboard 802.11 b/g/n wifi + Bluetooth 4.0 Module
- USB2.0 Type-A HOST x1
- USB3.0 Type-C OTG x1
- 26-pin expansion header
- USB Type-C DC 5V Power Supply
Linux commit commit for the same,
<2e04c25b1320> ("arm64: dts: rockchip: add ROCK Pi S DTS support")
Signed-off-by: Akash Gajjar <gajjar04akash@gmail.com>
Add Radxa ROCK 3 Model A support. sync rk3568-rock-3a.dts from Linux 6.2.0-rc7
Board Specifications
- Rockchip RK3568
- 2/4/8GB LPDDR4 3200MT/s
- eMMC socket, SD card slot
- GbE LAN
- PCIe 3.0/2.0
- M.2 Connector
- 3.5mm Audio jack with mic
- HDMI 2.0, MIPI DSI/CSI
- USB 3.0 Host/OTG, USB 2.0 Host
- 40-pin GPIO expansion ports
- USB Type C PD 2.0, 9V/2A, 12V/2A, 15V/2A, 20V/2A
Refer Linux commit <22a442e6586c>
("arm64: dts: rockchip: add basic dts for the radxa rock3 model a")
This converts 13 usages of this option to the non-SPL form, since there is
no SPL_EFI_HAVE_CAPSULE_SUPPORT defined in Kconfig
Add information that will be needed for enabling the UEFI capsule
update feature on the RockPi4 boards. With the feature enabled, it
would be possible to update the idbloader and u-boot.itb images on the
RockPi4B and RockPi4C variants.
Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org>
Specification
- Rockchip RK3399
- LPDDR3 4GB
- TF sd scard slot
- eMMC
- AP6255 for WiFi + BT
- Gigabit ethernet
- HDMI out
- 40 pin header
- USB 2.0 x 2
- USB 3.0 x 1
- USB 3.0 Type-C x 1 work in otg mode
- 12V DC Power supply
The dts file is sync from linux-next[0].
[0]:https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/tree/arch/arm64/boot/dts/rockchip/rk3399-eaidk-610.dts
Signed-off-by: Andy Yan <andyshrk@163.com>
A number of rk3229/rk3288 DT files are synced from Linux.
Add a maintainer to look after them and to help with
review and testing.
Signed-off-by: Johan Jonker <jbx6244@gmail.com>
Add support for rk3568 evaluation board.
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Add initial support for NanoPi M4B, a minor revision of
the original NanoPi M4.
Commit details of rk3399-nanopi-m4b.dts sync from Linux 5.12-rc4:
"arm64: dts: rockchip: Add NanoPi M4B board"
(sha1: c7b03115003f7f337ab165542cee37148cf30a8a)
Signed-off-by: Alexandre Vicenzi <alexandre.vicenzi@suse.com>
Reviewed-by: Kever Yang <kever.yang@rock-cihps.com>
NanoPi R4s is SBC base on Rockchip RK3399 hexa-core processor with
dual-Core Cortex-A72 and Mali-T864 GPU with 4GiB(LPDDR4) of RAM, SD card support,
including 2 gigabit ethernet(RTL8211E 1Gbps - RTL8111H 1Gbps) and 2 USB 3.0 port.
port.It also has two GPIO headers which allows further peripherals to be used.
The devicetree file is taken of the rk3399 nanopi4 Linux kernel [1].
[1] https://github.com/torvalds/linux/commit/e7a095908227fb3ccc86d001d9e13c9ae2bef8e6
Signed-off-by: xiaobo <peterwillcn@gmail.com>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
This adds support for the NanoPi R2S from FriendlyArm.
Rockchip RK3328 SoC
1GB DDR4 RAM
Gigabit Ethernet (WAN)
Gigabit Ethernet (USB3) (LAN)
USB 2.0 Host Port
MicroSD slot
Reset button
WAN - LAN - SYS LED
Signed-off-by: David Bauer <mail@david-bauer.net>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
Use board_early_init_f() instead of mach_cpu_init() for board, the
board_early_init_f() is used for board init and after dm_initf, while
the mach_cpu_init() is used for CPU/SOC and before dm_initf()(not able
to use syscon API).
Fixes: 9cec336708 ("rockchip: evb-rv1108: Use syscon API to get grf base")
Fixes: 4aa33690fc {"rockchip: elgin-rv1108: Use syscon API to get grf base")
Rock PI 4C has AP6256 Wifi/BT, PoE, miniDP, USB Host enabled
GPIO pin change compared to 4B, 4C.
So, add or enable difference nodes/properties in 4C dts
by including common dtsi.
Rock Pi N8 is a Rockchip RK3288 based SBC, which has
- VMARC RK3288 SOM (as per SMARC standard) from Vamrs.
- Compatible carrier board from Radxa.
VAMRC RK3288 SOM need to mount on top of radxa dalang
carrier board for making Rock Pi N8 SBC.
So, add initial support for Rock Pi N8 by including rk3288,
rk3288 vamrc-som and raxda dalang carrier board dtsi files.
Rock Pi N10 is a Rockchip RK3399Pro based SBC, which has
- VMARC RK3399Pro SOM (as per SMARC standard) from Vamrs.
VAMRC RK3399Pro SOM need to mount on top of radxa dalang
carrier board for making Rock Pi N10 SBC.
So, add initial support for Rock Pi N10 by including rk3399,
rk3399pro vamrc-som and raxda dalang carrier board dtsi files.
rk3399pro-rock-pi-n10.dts was synced from linux-next v5.7-rc1.
Tested
- ROCK PI N10 Model B
- ROCK PI N10 Model C
- Boot from SD
This commit add the default configuration file and relevant description
for rock-pi-e board
Signed-off-by: Banglang Huang <banglang.huang@foxmail.com>
When building U-Boot we select the architecture via Kconfig and not ARCH
being passed in via the environment or make cmdline.
Acked-by: Kever Yang <kever.yang@rock-chips.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Acked-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
commit b2f5da9dd068 ("rockchip: rk3399: Add Nanopi M4 board support") added
support for Nanopi M4 board with Dual-Channel 4GB LPDDR3-1866 RAM.
This patch adds another variant of NanoPi M4 board with Dual-Channel
2GB DDR3-1866 RAM.
Signed-off-by: Deepak Das <deepakdas.linux@gmail.com>
The ROC-RK3328-CC from Firefly and Libre Computer Project is a credit
card size development board based on the Rockchip RK3328 SoC, with:
- 1/2/4 GB DDR4 DRAM
- eMMC connector for optional module
- micro SD card slot
- 1 x USB 3.0 host port
- 2 x USB 2.0 host port
- 1 x USB 2.0 OTG port
- HDMI video output
- TRRS connector with audio and composite video output
- gigabit Ethernet
- consumer IR receiver
- debug UART pins
The ROC-RK3328-CC has the enable pin of the SD card power switch tied
to GPIO_0_D6. This pin also has the function SDMMC0_PWREN, which is
muxed by default. SDMMC0_PWREN is an active high signal controlled by
the MMC controller, however the switch enable is active low, and
pulled low (enabled) by default to make things work on boot.
As such, we need to mux away from SDMMC0_PWREN and use GPIO to enable
power to the card. The default GPIO state for the pin is pull-down and
input, which doesn't require extra configuration when paired with the
external pull-down and active low switch.
Deal with this by enabling regulator support in SPL, and setting
"u-boot,dm-spl" for the regulator and other device nodes needed for
muxing the pin.
The device tree file is synced from the Linux kernel next-20200324.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Use syscon API to get grf base instead of get from dts.
roc-pc-rk3399 board has one user button & three user LED's. Currently
we don't have any code support for these devices. Since button and LED's are
specific to roc-pc-rk3399 board, split it into its own board file and add code
support here.
Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com>
This is a core board named Core-PX30-JD4 with a mainboard from Firefly,
name it as firefly-px30 for now.
This board can re-use the dts of PX30, the only difference is the UART IO,
the firefly use UART2 M1 while evb use UART2 M0.
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
These functions do not use driver model but are still used. Move them to a
new eeprom.h header file.
A number of board function belong in init.h with the others. Move them.
Support tinker-s board. The board is equivalent of tinker board
except of emmc.
TODO:
- support of usb current burst when the board is powered from pc
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Add support for rk3308 evaluation board.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
rockpro64 needs to setup I/O domains in order for USB to work in u-boot.
Since we currently don't have a driver to do that, split it into its own
board file and initialize I/O domains here.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
roc-rk3399-pc_defconfig is committed in below
commit <8a681f4c5aa15db51ad0209734859c9fe7c29cfd> ("rockchip: rk3399:
Add ROC-RK3399-PC support")
which doesn't follow the existing defconfigs on rk3399.
So, rename as followed with other rk3399 defconfigs.
Cc: Levin Du <djw@t-chip.com.cn>
The px30 evb is an evaluation board for the px30 together with a dsi-
connected display. This adds board and config files for it.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
Specification
- Rockchip RK3399
- LPDDR4
- TF sd scard slot
- eMMC
- M.2 B-Key for 4G LTE
- AP6256 for WiFi + BT
- Gigabit ethernet
- HDMI out
- 40 pin header
- USB 2.0 x 2
- USB 3.0 x 1
- TYPE-C Power supply
Commit details of rk3399-leez-p710.dts sync from linus tree for Linux 5.4-rc1:
"arm64: dts: rockchip: Add dts for Leez RK3399 P710 SBC"
(sha1: fc702ed49a8668a17343811ee28214d845bfc5e6)
Signed-off-by: Andy Yan <andyshrk@gmail.com>
Since there is no one using this board, remove it.
Add initial support for ROC-RK3399-PC board.
Specification
- Rockchip RK3399
- LPDDR4 4GiB
- eMMC slot
- SD card slot
- RTL8211E 1Gbps
- HDMI Out, DP, MIPI DSI/CSI, EDP
- PCIe M.2
- USB 2.0, USB-3.0
- USB C Type
Commit details of rk3399-roc-pc.dts sync from Linux v5.2:
"arm64: dts: rockchip: add support for ROC-RK3399-PC board"
(sha1: 8bb878cf20ae10809c36db96993bfce7026d062b)
Signed-off-by: Levin Du <djw@t-chip.com.cn>
This header file is now only used by files that access internal
environment features. Drop it from various places where it is not needed.
Move env_set() over to the new header file.
Add devicetree support for Khadas Edge-Captain.
Khadas Captain is the carrier board for Khadas Edge.
Specification
- Rockchip RK3399
- Dual-Channel 2GB/4GB LPDDR4
- SD card slot
- Onboard 16GB/32GB/128GB eMMC
- RTL8211FD 1Gbps
- AP6356S/AP6398S WiFI/BT
- HDMI Out, DP, MIPI DSI/CSI, eDP
- USB 3.0, 2.0
- USB Type C power and data
- GPIO expansion ports
- Full 4 Lane M.2 Socket
- 16MB SPI Flash
- IR
- Programmable MCU
Commit details of rk3399-khadas-edge-*.dts sync from Linux 5.3-rc2:
"arm64: dts: rockchip: Add support for Khadas Edge/Edge-V/Captain boards"
(sha1: c2aacceedc86af87428d998e23a1aca24fd8aa2e)
Signed-off-by: Nick Xie <nick@khadas.com>
Tested-by: Chris Webb <chris@arachsys.com>
Add devicetree support for Khadas Edge-V.
Khadas Edge-V is a Khadas VIM form factor Rockchip RK3399 board.
Specification
- Rockchip RK3399
- SD card slot
- RTL8211FD 1Gbps
- USB 3.0, 2.0
- 16MB SPI Flash
- IR
- Programmable MCU
Add devicetree support for Khadas Edge.
Khadas Edge is an expandable Rockchip RK3399 board with goldfinger.
Specification
- Rockchip RK3399
- RTL8211FD 1Gbps
- HDMI Out, DP
- USB 3.0, 2.0
- 16MB SPI Flash
- Programmable MCU
Use common board file for board_init() and board_late_init(),
for Rockchip SoCs have very similar process.
Handle per-board init in board_early_init_f() and use the
common board_init() for per-platform board init later.
Tested-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
