path: root/board/rockchip
2019-06-26rockchip: rk3399: Fix enabling boot-on regulatorsMark Kettenis
The new common rockchip pinctrl driver does not support explicit requests for a particular pinctrl function. As a result, the board_init() function bails out early before enabling the boot-on regulators. Fix this by simply removing the request for pwm0, pwm2 and pwm3. The generic DM code already does the necessary configuration if necessary. Reported-by: Levin Du <djw@t-chip.com.cn> Signed-of-by: Mark Kettenis <kettenis@openbsd.org>
2019-06-26rockchip: rk3399: Support common spl_board_initJagan Teki
Support common spl_board_init by moving code from puma board file into, common rk3399-board-spl.c. Part of the code has sysreset-gpio, regulators_enable_boot_on but right now only puma board is using this with relevant config options rest remains common for all targets. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26board: rk3399: Drop explicit uart enablement in spl_board_initJagan Teki
preloader_console_init is used for printing SPL boot banner that usually called from spl_board_init. The current spl_board_init in evb and rock960 is enabling explicit pinctrl, debug uart prior to calling preloader_console_init which eventually not required since board_init_f is already enabled debug uart. So, drop those explicit enablement calls from spl_board_init of evb, rock960. Tested this by enabling CONFIG_SPL_BOARD_INIT and adding u-boot,dm-pre-reloc property for uart node. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26rockchip: rk3328: add rock64-rk3328_defconfigMatwey V. Kornilov
The ROCK64 is a credit card size SBC based on Rockchip RK3328 Quad-Core ARM Cortex A53. This series allow building u-boot SPL and u-boot.itb for Rock64 board. The proprietary TPL is stil required for deploy: ./tools/mkimage -n rk3328 -T rksd \ -d ./rkbin/bin/rk33/rk3328_ddr_333MHz_v1.16.bin idbloader.img cat ./spl/u-boot-spl.bin >> idbloader.img dd if=idbloader.img of=/dev/sdcard seek=64 conv=notrunc dd if=u-boot.itb of=/dev/sdcard seek=16384 conv=notrunc Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-30rockchip: rk3399: Add Rock PI 4 supportJagan Teki
Add initial support for Rock PI 4 board. Specification - Rockchip RK3399 - LPDDR4 - eMMC - SD card slot - RTL8211E 1Gbps - HDMI In/Out, DP, MIPI DSI/CSI - PCIe M.2 - USB 2.0, USB-3.0 - USB C Type Commit details of rk3399-rock-pi-4.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: add ROCK Pi 4 DTS support" (sha1: 1b5715c602fda7b812af0e190eddcce2812e5417) Signed-off-by: Akash Gajjar <akash@openedev.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-30rockchip: rk3399: Add Rockpro64 board supportJagan Teki
Add initial support for Rockpro64 board. Specification - Rockchip RK3399 - 2/4GB Dual-Channel LPDDR3 - SD card slot - eMMC socket - 128Mb SPI Flash - Gigabit ethernet - PCIe 4X slot - WiFI/BT module socket - HDMI In/Out, DP, MIPI DSI/CSI, eDP - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 12V/2A Commit details of rk3399-rockpro64.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: rockpro64 dts add usb regulator" (sha1: 6db644c79c8d45d73b56bc389aebd85fc3679beb) 'Akash' has sent an initial patch before, so I keep him as board maintainer and I'm co-maintainer based on our conversation. Signed-off-by: Akash Gajjar <akash@openedev.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-30rockchip: rk3399: Add Nanopi NEO4 board supportJagan Teki
Add initial support for Nanopi NEO4 board. Specification - Rockchip RK3399 - 1GB DDR3-1866 - SD card slot - eMMC Socket - RTL8211E 1Gbps - AP6212 WiFI/BT - HDMI In/Out, DP, MIPI CSI - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 5V/3A Commit details of rk3399-nanopi-neo4.dts sync from Linux: "arm64: dts: rockchip: Add Nanopi NEO4 initial support" (sha1: 092470b537f19788d957aed12d835a179b606014) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-09rockchip: rk3399: Add Nanopc T4 board supportJagan Teki
Add initial support for Nanopc T4 board. Specification - Rockchip RK3399 - Dual-Channel 4GB LPDDR3-1866 - SD card slot - 16GB eMMC - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI, eDP - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 12V/2A Commit details of rk3399-nanopc-t4.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: Add NanoPC-T4 IR receiver" (sha1: 95658e21b1707ad7844f873db2fdaa295109a5a3) Tested-by: Daniel Gröber <dxld@darkboxed.org> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-09rockchip: rk3399: Add Nanopi M4 board supportJagan Teki
Add initial support for Nanopi M4 board. Specification - Rockchip RK3399 - Dual-Channel 4GB LPDDR3-1866 - SD card slot - eMMC socket - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - USB 3.0 x4 - USB Type C power and data - GPIO1, GPIO2 expansion ports - DC5V/3A Commit details of rk3399-nanopi-m4.dts sync from Linux 5.1-rc2: "arm64: dts: rockchip: Refine nanopi4 differences" (sha1: c62ffaf5026d0b7633e62b2cea8450b5543c349a) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-05-08rockchip: evb-rk3229: add README file for OP-TEE supportKever Yang
Detail of step by step to bring up the board with OP-TEE support. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-01rockchip: use 'arch-rockchip' as header file pathKever Yang
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common header file path, so that we can get the correct path directly. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-05-01rockchip: rk3399: Add Orangepi RK3399 supportJagan Teki
Add initial support for Orangepi RK3399 board. Specification - Rockchip RK3399 - 2GB/4GB DDR3 - 16GB eMMC - SD card slot - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - Mini PCIe - Sensors, Keys etc - DC12V-2A and DC5V-2A Commit details about Linux DTS sync: "arm64: dts: rockchip: Add support for the Orange Pi RK3399" (sha1: d3e71487a790979057c0fdbf32f85033639c16e6) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: evb_rk3399: Tidy up the READMESimon Glass
Add mention of a prerequisite needed to build the image. Also adjust the English wording in a few places. Ideally this should move to using binman to produce images, and avoid the manual steps. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-07-21rockchip: evb-rk3399: correct README for board bring upHeinrich Schuchardt
%s/rkflashtool/rkdeveloptool/ We are using rkdeveloptool not rkflashtool. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-28rockchip: pinctrl: rv1108: Move the iomux definitions into pinctrl-driverDavid Wu
If we include both the rk3288_grf.h and rv1108_grf.h, it will cause the conflicts of redefinition. Clean the iomux definitions at grf_rv1108.h, and move them into pinctrl-driver. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: evb-rk3399: update document for board bring upKever Yang
Since we support ATF in SPL and add script for it, let's make the document up to date. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-30rockchip: board: evb-rk3128: add empty MakefilePhilipp Tomsich
Even if the board-specific directory Makefile doesn't have any targets, it still needs to exist. This adds a minimal Makefile for the board/rockchip/evb_rk3128 directory and a evk-rk3128.c (as built-in.o needs to be built for every directory that a Makefile gets run for). Fixes: c7a6866 ("rockchip: rk3128: add evb-rk3128 support") Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-30rockchip: rk3128: add evb-rk3128 supportKever Yang
evb-rk3128 is an evb from Rockchip based on rk3128 SoC: - 2 USB2.0 Host port; - 1 HDMI port; - 2 10/100M eth port; - 2GB ddr; - 16GB eMMC; - UART to USB debug port; Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-30rockchip: board: evb_rv1108: update READMEAndy Yan
After commit d962e5dadc2c("rockchip: mkimage: use spl_boot0 for all Rockchip SoCs"), the mkimage will not pad the Tag memroy, so we shoud pass a Taged ddr.bin/spl.bin to it. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-01rockchip: rk3399: make spl_board_init board-specificPhilipp Tomsich
The later-stage spl_board_init (as opposed to board_init_f) should set up board-specific details: these differ between the EVB-RK3399 and the RK3399-Q7 (Puma). This moves spl_board_init back into the individual boards and removes the unneeded functionality from Puma. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: remove the hard coded uart iomux setting for px5 evbAndy Yan
As the debug uart is marked as dm-pre-reloc, the pinctrl driver will handle the correct iomux setting. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11rockchip: evb-rk3328: enable boot on regulatorKever Yang
Enable all the boot-on regulator in default. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: rk3328: board: add support of dwc2 gadgetMeng Dongyang
Probe dwc2 udc in the function of board_usb_start to enable usb gadget function. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: add evb_rk3229 boardKever Yang
evb_rk3229 is a RK3229 based board, with: - 8GB eMMC; - 1GB DDR SDRAM; - 2 USB2.0 HOST port; - 1 MAC port; - 1 HDMI port; - IR; - WiFi; Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: correct the bank0 ram sizeKever Yang
The bank0 ram size should be the DRAM size minus reserved size, the DRAM size may be 1GB, 2GB, 4GB, we can not hard code it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added DECLARE_GLOBAL_DATA_PTR for RK3328, RK3368 and RK3399: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: use common sdram functionKever Yang
Replace the sdram_init() in board init and rockchip_sdram_size() in sdram driver for all the Rockchip SoCs which enable CONFIG_RAM. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Make dram_init() in rk3036-board.c conditional on CONFIG_RAM: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: rk3328: don't implement usb_gadget_handle_interrupts twicePhilipp Tomsich
The usb_gadget_handle_interrupts()-function is already implemented by drivers/usb/gadget/dwc2_udc_otg.c, so we need to avoid defining it in the evb-rk3328.c board-specific file. This change fixes the following build error (from buildman): drivers/usb/gadget/built-in.o: In function `usb_gadget_handle_interrupts': build/../drivers/usb/gadget/dwc2_udc_otg.c:850: multiple definition of `usb_gadget_handle_interrupts' board/rockchip/evb_rk3328/built-in.o:build/../board/rockchip/evb_rk3328/evb-rk3328.c:37: first defined here make[1]: *** [u-boot] Error 1 Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: Add basic support for evb-rv1108 boardAndy Yan
Add basic support for rv1108 evb, whith this patch we can boot into u-boot console. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: evb-rk3328: update board maintainerKever Yang
Update maintainer to Kever Yang for William Zhang is not work for this board now. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: rk3368: Add PX5 Evaluation boardAndy Yan
PX5 EVB is designed by Rockchip for automotive field with integrated CVBS (TP2825) / MIPI DSI / CSI / LVDS HDMI video input/output interface, audio codec ES8396, WIFI / BT (on RTL8723BS), Gsensor BMA250E and light&proximity sensor STK3410. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: rk3368: add Sheep boardAndy Yan
Sheep board is designed by Rockchip as a EVB for rk3368. Currently it is able to boot a linux kernel and system to console with the miniloader run as fist level loader. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
2017-05-10rockchip: board: evb_rk3399: initialize pwm0 for dispaly backlightEric Gao
Enable pwm0 for display of rk3399 evb board. The PWM do not have decicated interrupt number in dts and can not get periph_id by pinctrl framework. So init them here. Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: tinker: set ethaddr in late initJonas Karlman
Set ethernet mac address in late init for Tinker Board, prevents getting a random mac address each boot. Read mac address from eeprom, first 6 bytes from m24c08@50. Same as /etc/init.d/rockchip.sh on Tinker OS. Signed-off-by: Jonas Karlman <jonas@kwiboo.se> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: rk3399: use actual dram sizeKever Yang
Since our sdram driver is ready, we can use the actual size instead of hard code. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: rk3399: use regulators_enable_boot_on() to init regulatorKever Yang
Use regulators_enable_boot_on() instead of init regulators one by one, the interface can init all the regulators with regulator-boot-on property. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-16rockchip: rk3328: add evb-rk3328 supportKever Yang
evb-rk3328 is an evb from Rockchip based on rk3328 SoC: - 2 USB2.0 Host port; - 1 USB3.0 Host port; - 1 HDMI port; - 2 10/100M eth port; - 2GB ddr; - 16GB eMMC; - UART to USB debug port; Signed-off-by: William Zhang <william.zhang@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-02-09rockchip: rename miniarm to tinker boardEddie Cai
Miniarm is the internal project code. Now it is officially named Tinker board. So rename it. Signed-off-by: Eddie Cai <eddie.cai@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-25evb-rk3399: deduced the dram node size when space reservedKever Yang
The size dram node need to be deduced by the same amount of reserved space. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: add boot-mode support for rk3288, rk3036Jacob Chen
rockchip platform have a protocol to pass the the kernel reboot mode to bootloader by some special registers when system reboot. In bootloader we should read it and take action. We can only setup boot_mode in board_late_init becasue "setenv" need env setuped. So add CONFIG_BOARD_LATE_INIT to common header and use a entry "rk_board_late_init" to replace "board_late_init" in board file. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: move common function from board-file to rk3036-board.cJacob Chen
To keep it same with 3288 Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: miniarm: remove eMMC supportXu Ziyuan
The latest rk3288-miniarm board doesn't have eMMC device, so remove it. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: evb_rk3399: init vdd_center regulatorKever Yang
Add vdd_center pwm regulator get_device to enable this regulator. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22board: evb-rk3399: enable usb 2.0 host vbus power on board_initKever Yang
rk3399 using one gpio control signal for two usb 2.0 host port, it's better to enable the power in board file instead of in usb driver. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
