path: root/board/rockchip/sheep_rk3368/Makefile
2017-06-07rockchip: rk3368: add Sheep boardAndy Yan
Sheep board is designed by Rockchip as a EVB for rk3368. Currently it is able to boot a linux kernel and system to console with the miniloader run as fist level loader. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
