path: root/board/rockchip/evb_rk3399
2017-05-10rockchip: board: evb_rk3399: initialize pwm0 for dispaly backlightEric Gao
Enable pwm0 for display of rk3399 evb board. The PWM do not have decicated interrupt number in dts and can not get periph_id by pinctrl framework. So init them here. Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: rk3399: use actual dram sizeKever Yang
Since our sdram driver is ready, we can use the actual size instead of hard code. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: rk3399: use regulators_enable_boot_on() to init regulatorKever Yang
Use regulators_enable_boot_on() instead of init regulators one by one, the interface can init all the regulators with regulator-boot-on property. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-11-25evb-rk3399: deduced the dram node size when space reservedKever Yang
The size dram node need to be deduced by the same amount of reserved space. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: evb_rk3399: init vdd_center regulatorKever Yang
Add vdd_center pwm regulator get_device to enable this regulator. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22board: evb-rk3399: enable usb 2.0 host vbus power on board_initKever Yang
rk3399 using one gpio control signal for two usb 2.0 host port, it's better to enable the power in board file instead of in usb driver. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22rk3399: enable the pwm2/3 pinctrl in board initKever Yang
There is no interrupt line for each PWM which used by pinctrl to get the periph_id, so it's not able to enable the default pinctrl setting by pinctrl framework, let's enable it at board_init(). Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-27rockchip: rk3399: update MAINTAINER fileKever Yang
This patch add maintainer information for rk3399 evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-07-31rk3399: Reserve space for ARM Trust FirmwareKever Yang
RK3399 needs reserve 0x200000 at the beginning of DRAM, for ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25ARM64: evb-rk3399: add a README for this board setupKever Yang
Add a README to guide people flash the ATF and U-Boot with Rockchip tools to bring up to board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25ARM64: rockchip: add support for rk3399 SoC based evbKever Yang
RK3399 is a SoC from Rockchip with dual-core Cortex-A72 and quad-core Cortex-A53 CPU. It supports two USB3.0 type-C ports and two USB2.0 EHCI ports. Other interfaces are very much like RK3288, the DRAM are 32bit width address and support address from 0 to 4GB-128MB range. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
