path: root/board/rmu/Makefile
2011-12-08MPC850: remove obsolete "rmu" BoardWolfgang Denk
The "rmu" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
