path: root/board/renesas
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-12-02sh: Add support for ecovec boardNobuhiro Iwamatsu
The ecovec board has SH7724, 256MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 256MB DDR2-SDRAM - USB - I2C - Ethernet Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: Add a flag which controls the DDR ECC mode of sh7757lcrNobuhiro Iwamatsu
When DDR-ECC is effective, the physical memory which can be used reduces this boardby half. However, this mode can chenge to disable. When it was disabled, user can use 512 MB of physical memory. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: "Yoshihiro Shimoda" <yoshihiro.shimoda.uh@renesas.com> Acked-by: "Yoshihiro Shimoda" <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: sh7757lcr: Add KEEP order to start.o sectionYoshihiro Shimoda
The sh7757lcr has a local u-boot.lds because the sh7757lcr is only supported the SPI booting. This patch refers from the commit "sh: Add KEEP order to start.o section" (commit ID: b52da2aed8c2c388661f369052a97d5b5c9ed00a). Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Fix rsk7203 alignment problemPhil Edworthy
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-06-01sh: sh7785lcr: Update BSC of USB areaNobuhiro Iwamatsu
A value of BSC of the USB was wrong. This updates this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27Coding Style cleanup: remove trailing empty linesWolfgang Denk
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-02-03sh: sh7785lcr: Fix out of tree buildingNobuhiro Iwamatsu
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: Remove config.mk for sh7785lcr boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: Remove config.mk for sh7763rdp boardNobuhiro Iwamatsu
2011-02-02sh: Remove config.mk for rsk7203 boardNobuhiro Iwamatsu
2011-02-02sh: Remove config.mk for r7780mp boardNobuhiro Iwamatsu
2011-02-02sh: Remove config.mk for r2dplus boardNobuhiro Iwamatsu
2011-02-02sh: Remove config.mk for ap325rxa boardNobuhiro Iwamatsu
2011-02-02sh: Remove config.mk for MigoR boardNobuhiro Iwamatsu
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-10-21sh: sh7785lcr: Add CONFIG_SYS_TEXT_BASE for 32bit modeNobuhiro Iwamatsu
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-30sh: Update lowlevel_init.S of ap325rxaNobuhiro Iwamatsu
Fix data size. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-08-30sh: Update lowlevel_init.S of r2dplusNobuhiro Iwamatsu
2010-08-30sh: Update lowlevel_init.S of sh7763rdpNobuhiro Iwamatsu
2010-08-30sh: Update lowlevel_init.S of MigoRNobuhiro Iwamatsu
2010-08-30sh: Update lowlevel_init.S of sh7785lcrNobuhiro Iwamatsu
2010-08-30sh: Update lowlevel_init.S of rsk7203Nobuhiro Iwamatsu
Update data address size and fix typo of register. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-30sh: Move some defs to convince 'pcrel too far'Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Takashi Yoshii <yoshii.takashi@gmail.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23sh/rsk7203: add missing include net.hJean-Christophe PLAGNIOL-VILLARD
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-07-08sh: Revised the build with newest compilerNobuhiro Iwamatsu
The check of data became severe from newest gcc. This patch checked in gcc-4.2 and 4.3 . Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all sh boards use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: make the linker scripts more genericJean-Christophe PLAGNIOL-VILLARD
currently we need to sync the linker script enty and TEXT_BASE manualy and the reloc_dst is based on it instead provide it now from the ldflags tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh7785lcr: fix out of tree buildJean-Christophe PLAGNIOL-VILLARD
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-15Prepare 2009.03-rc2v2009.03-rc2Wolfgang Denk
Update CHANEGLOG, fix minor coding style issue. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-13sh: ap325rxa: Change the wait cycle in the area 5Yusuke.Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: Add support 32-Bit Extended Address Mode to sh7785lcrYoshihiro Shimoda
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb" for this mode. This command changes PMB for using 512MB system memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-16sh: Fix compile error on lowlevel_init fileNobuhiro Iwamatsu
lowlevel_init of SH was corrected to use the write/readXX macro. However, there was a problem that was not able to be compiled partially. This patch corrected this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: Fix up rsk7203 target for out of tree buildKieran Bingham
Fix up rsk7203 target to build successfully using out-of-tree build. Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: use write{8,16,32} in all lowlevel_initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
