path: root/board/renesas
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-07-24arm: rmobile: Add support Alt boardNobuhiro Iwamatsu
The alt board has R8A7794, 1GB DDR3-SDRAM, USB, Ethernet, QSPI, MMC, SDHI and more. This commit supports the following functions: - DDR3-SDRAM - SCIF - I2C - Ethernet - QSPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Fix QoS revision 0.240 and 0.320Nobuhiro Iwamatsu
Add register define of DBSC3 operation adjustment register, and add initial value. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-04-28arm: rmobile: lager: Remove MACH_TYPE_LAGER and CONFIG_MACH_TYPENobuhiro Iwamatsu
MACH_TYPE_LAGER and CONFIG_MACH_TYPE are not already available on Lager board. This removes them. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Change to maximum CPU frequencyNobuhiro Iwamatsu
Maximum CPU clock of R8A7790 that are used in lager board is 1.4GHz. This change to use the maximum clock in this board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: koelsch: Change to maximum CPU frequencyNobuhiro Iwamatsu
Maximum CPU clock of R8A7791 that are used in koelsch board is 1.5GHz. This change to use the maximum clock in this board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: koelsch: Update QoS initializationNobuhiro Iwamatsu
This update QoS version 0.240 for ES1 and version 0.310 for ES2. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Update QoS initialization to version 0.955Nobuhiro Iwamatsu
2014-04-28arm: rmobile: keolsch: Add support ES2 revision of R8A7791Nobuhiro Iwamatsu
There is koelsch where ES2 revision of R8A7791 was put on. This is different in Qos setting. This adds Qos setting for ES2 revision of R8A7791. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Remove NOR-Flash supportNobuhiro Iwamatsu
Lagar board has NOR-Flash. But user uses SPI-Flash ROM instead of NOR-Flash. This removed the setting of NOR-Flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: lager: Change name of the structureNobuhiro Iwamatsu
This changes from r8a7790_ to rcar_. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: koelsch: Remove NOR-Flash supportNobuhiro Iwamatsu
Koelsch board has NOR-Flash. But user uses SPI-Flash ROM instead of NOR-Flash. This removed the setting of NOR-Flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: koelsch: Change name of structureNobuhiro Iwamatsu
This changes from r8a7791_ to rcar_. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-31board: ecovec: fix USB0 clock enableBaruch Siach
Enable USB0 clock by resetting bit 20 of MSTPCR2. Leave other bits unchanged. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-31board: ecovec: fix debug LEDs pin directionBaruch Siach
All pins should be output. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-14sh: ecovec: correct romImage address in commentBaruch Siach
romImage is set by CONFIG_ECOVEC_ROMIMAGE_ADDR to 0xA0040000. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-16arm: lager: Disable TMU0 before OS bootNobuhiro Iwamatsu
On U-boot uses TMU0 as timer, but TMU0 does not use on linux kernel and other. This disables TMU0 at the request of from kernel user. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-16arm: koelsch: Disable TMU0 before OS bootNobuhiro Iwamatsu
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-18sh: add support for sh7753evb boardYoshihiro Shimoda
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch support the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-18arm: koelsch: Add support reset functionNobuhiro Iwamatsu
2013-12-18arm: koelsch: Add support EthernetNobuhiro Iwamatsu
The koelsch board has one sh-ether device. This supports sh-ether. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-18arm: lager: Add support reset functionNobuhiro Iwamatsu
The lager board uses I2C for reset. ned-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-18arm: lager: Add support EthernetNobuhiro Iwamatsu
The lager board has one sh-ether device. This supports sh-ether. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-03arm: rmobile: Add support koelsch boardNobuhiro Iwamatsu
The koelsch board has R8A7791, 2GB DDR3-SDRAM, USB, Quad SPI, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-12-03arm: rmobile: Add support lager boardNobuhiro Iwamatsu
The lager board has R8A7790, 4GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-05-28sh: Add SH7269 device and RSK2+SH7269 boardPhil Edworthy
This is an sh2a device (max 266MHz) with FPU, video display controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports, SD and on-chip USB. The RSK2+SH7269 board uses the SH7269 processor. It is often referred to as just rsk7269. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-05-28sh: r0p7734: Add support I2C controllerNobuhiro Iwamatsu
This read MAC address from Serial EEPROM and set. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-05-28sh: Add support for r0p7734 boardNobuhiro Iwamatsu
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 128MB DDR2-SDRAM - 32MB NOR Flash memory - Serial console (SCIF) - Ethernet (SH-Ether/SMSC) Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-04-18sh: Fix rsk7264 pin setup for on-board ethernetPhil Edworthy
This sets up the external ethernet IRQ pin. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-26sh: Fix building ecovec boardPhil Edworthy
Build error was with board/renesas/ecovec/lowlevel_init.S include/version.h: Assembler messages: include/version.h:41: Error: unknown opcode lowlevel_init.S:48: Error: unknown opcode lowlevel_init.S:51: Error: unknown opcode etc Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-26sh: ecovec: Remove unused variableNobuhiro Iwamatsu
2012-03-26sh: sh7757lcr: Add MMC header file of SHNobuhiro Iwamatsu
2012-03-26sh: sh7757lcr: add supporting for MMCIFYoshihiro Shimoda
The sh7757lcr has 2GByte eMMC chip. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-19usb: replace wait_ms() with mdelay()Mike Frysinger
Common code has a mdelay() func, so use that instead of the usb-specific wait_ms() func. This also fixes the build errors: ohci-hcd.c: In function 'submit_common_msg': /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1519:9: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1816:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1827:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1844:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1563:11: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1583:9: sorry, unimplemented: called from here make[1]: *** [ohci-hcd.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marex@denx.de>
