path: root/board/renesas
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-02-25arm: rmobile: silk: Add support SDHIVladimir Barinov
This adds GPIO configuration and initialization function of SDHI on Silk board Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: fix typo in device declarationVladimir Barinov
Fix typo in device declaration Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Disable ethernet pins pull-upVladimir Barinov
Disable pull-ups on ethrenet lines Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Fix GPIO4_31 initializationVladimir Barinov
Use gpio_direction_output instead of gpio_set_value since the latter does not set output GPIO direction. Signed-off-by: Valentine Barshak <valentine.barshak+renesas@cogentembedded.com> Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: Add Porter board supportVladimir Barinov
Porter is an entry level development board based on R-Car M2 SoC (R8A7791) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, SD, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Add support SDHINobuhiro Iwamatsu
Lager board has two SDHI port as SDHI0 and SDHI2. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Add support SDHINobuhiro Iwamatsu
Gose board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Add support SDHINobuhiro Iwamatsu
Koelsch board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Add support SDHINobuhiro Iwamatsu
Alt board has two SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Silk board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Alt board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Lager board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Gose board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Koelsch board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13ARM: rmobile: silk: Remove initialization of ACTLR.SMPNobuhiro Iwamatsu
Initialization of ACTLR.SMP is in lowlevel_init. This remove duplicate function. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13arm: rmobile: Add missed header file for Silk boardVladimir Barinov
This file was missed in the commit https://patchwork.ozlabs.org/patch/427801/ Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13arm: rmobile: Add SILK board supportVladimir Barinov
SILK is an entry level development board based on R-Car E2 SoC (R8A7794) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, MMC, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-10arm: rmobile: alt: Add support MMC and MMC commandNobuhiro Iwamatsu
Alt board has been connected to eMMC of 8GB to MMC port. This enables MMC port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-10arm: rmobile: lager: Add support MMC and MMC commandNobuhiro Iwamatsu
Lager board has been connected to eMMC of 8GB to MMC1 port. This enables MMC1 port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Stop clock prior to booting kernelNobuhiro Iwamatsu
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Move arch_preboot_os function to rcar-gen2-common/common.cNobuhiro Iwamatsu
The arch_preboot_os function used in boards using R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794) is common. This makes rcar-gen2-common/common.c file providing common function for R-Car ARM SoC, and moves this function to this file. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Move control macro of mstp to arch-rmobile/rcar-mstp.hNobuhiro Iwamatsu
Control macro of mstp is common in R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794). This moves these to arch-rmobile/rcar-mstp.h Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Move module control register to header file of SoCNobuhiro Iwamatsu
Module control registers of R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794) are same address. This moves these to header file of SoC. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2014-11-17arm: rmobile: gose: Remove dram_init_banksize functionNobuhiro Iwamatsu
Gose board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of dram_init_banksize instead. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: lager: Remove dram_init_banksize functionNobuhiro Iwamatsu
Lager board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of dram_init_banksize instead. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: koelsch: Remove dram_init_banksize functionNobuhiro Iwamatsu
Koesch board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of dram_init_banksize instead. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: alt: Remove dram_init_banksize functionNobuhiro Iwamatsu
Alt board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of dram_init_banksize instead. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-13sh: consolidate CONFIG_SYS_CPU definesMasahiro Yamada
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3, CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to arch/sh/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Remove i2c_init functionNobuhiro Iwamatsu
The i2c_init function is no longer necessary. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Fix typo in comment for sh-i2cNobuhiro Iwamatsu
PowerIC connected to channel 1 of sh-i2c, not channel 2. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Enable channel 1 of sh-i2cNobuhiro Iwamatsu
Alt board was connected Power IC to channel 1 of sh-i2c. Source code that controls this is already included, but channel 1 of sh-i2c is not enabled. This enables channel 1 of sh-i2c, and can use. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Remove board_late_init functionNobuhiro Iwamatsu
Alt board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: lager: Remove board_late_init functionNobuhiro Iwamatsu
Lager board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: koelsch: Remove board_late_init functionNobuhiro Iwamatsu
Koelsch board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: gose: Add Ethernet supportNobuhiro Iwamatsu
Gose board has one ether port, this works using sh-ether driver. This adds GPIO settings and driver settings in order to use the sh-ether. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Add support gose boardNobuhiro Iwamatsu
The gose board has R8A7793, 1GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF - QSPI - SPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10board/renesas/ecovec/ecovec.c: fix buffer overflowWolfgang Denk
Fix error detected by cppcheck: [board/renesas/ecovec/ecovec.c:66]: (error) Buffer is accessed out of bounds. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: alt: Fix typo of SCIF idNobuhiro Iwamatsu
Alt board use SCIF2, not SCIF0. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: alt: Remove RAM address initializationNobuhiro Iwamatsu
Since board info structure is not still set up, the setting of RAM address causes illegal access. Therefore the setting of RAM address is removed. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: koelsch: Remove RAM address initializationNobuhiro Iwamatsu
2014-11-04arm: rmobile: lager: Remove RAM address initializationNobuhiro Iwamatsu
2014-11-04arm: rmobile: alt: Add external RAM bootNobuhiro Iwamatsu
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM. The default boot address is 0x70000000. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: koelsch: Add external RAM bootNobuhiro Iwamatsu
2014-11-04arm: rmobile: lager: Add external RAM bootNobuhiro Iwamatsu
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM. The default boot address is 0xB0000000. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: lager: Fix change of the CPU frequencyNobuhiro Iwamatsu
The change of the CPU frequency is waited for until PLL0ST of the PLLECR is set to 1. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-10-22sf: Tidy up public and private header filesSimon Glass
Since spi_flash.h is supposed to be the public API for SPI flash, move private things to sf_internal.h. Also tidy up a few comment nits. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-09arm: rmobile: lager: Fix CPU frequency settingNobuhiro Iwamatsu
Setting to change the CPU frequency is only used version2. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
