path: root/board/renesas
2009-03-15Prepare 2009.03-rc2v2009.03-rc2Wolfgang Denk
Update CHANEGLOG, fix minor coding style issue. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-13sh: ap325rxa: Change the wait cycle in the area 5Yusuke.Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: Add support 32-Bit Extended Address Mode to sh7785lcrYoshihiro Shimoda
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb" for this mode. This command changes PMB for using 512MB system memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-16sh: Fix compile error on lowlevel_init fileNobuhiro Iwamatsu
lowlevel_init of SH was corrected to use the write/readXX macro. However, there was a problem that was not able to be compiled partially. This patch corrected this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: Fix up rsk7203 target for out of tree buildKieran Bingham
Fix up rsk7203 target to build successfully using out-of-tree build. Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: use write{8,16,32} in all lowlevel_initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: lowlevel_init coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: r2dplus fix register accessJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: r2dplus/lowlevel_init: coding style fixJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: Migo-R: Update BSC valueNobuhiro Iwamatsu
A value of BSC CS4 was wrong, Fixed it. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-10-31sh: rsk7203: Moved rsk7203 board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: MigoR: Moved MigoR board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: r2dplus: Moved r2dplus board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: sh7763rdp: Moved sh7763rdp board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: sh7785lcr: Moved sh7785lcr board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: r7780mp: Moved r7780mp board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: ap325rxa: Moved ap325rxa board to board/renesasNobuhiro Iwamatsu
