In order to finish moving this symbol to Kconfig for all platforms, we
need to do a few more things. First, for all platforms that define this
to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to
CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails
also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk()
and updating a few preprocessor tests.
With that done, all platforms that define a value here can be converted
to Kconfig, and a fall-back of zero is sufficiently safe to use (and
what is used today in cases where code may or may not have this
available). Make sure that code which calls this function includes
<clock_legacy.h> to get the prototype.
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
Move this function out of common.h and into a relevant header file.
This file contains lots of internal details about the environment. Most
code can include env.h instead, calling the functions there as needed.
Rename this file and add a comment at the top to indicate its internal
nature.
[trini: Fixup apalis-tk1.c]
Move env_get() over to the new header file.
The PHY LED mode register mask should be 0xc000 , not 0xc0000.
Correct the mask to operate on the right bits.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
This patch renames the routine fdtdec_setup_memory_size()
to fdtdec_setup_mem_size_base() as it now fills the
mem base as well along with size.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Pull the symbol from the boards and zap struct rmobile_sysinfo as they
are rather useless. The entire purpose of that whole machinery was to
print board name in the CONFIG_ARCH_RMOBILE_BOARD_STRING. Do that in a
far simpler and more contained manner.
When U-Boot is started via JTAG, ignore the installed environment
as it may interfere with the recovery of the board.
There is currently no use for building the SPL anymore, since the
SPI loader can easily be replaced by TPL and TPL does load U-Boot
directly. Upgrade TPL to SPL and replace what used to be SPL with
it. This way we build the U-Boot sources only twice, not thrice.
The offset of CSWCRx starts at 0x30, fix this.
Add JTAG recovery support into the M2 Porter TPL. This allows the
TPL to be loaded over JTAG, initialize the system, wait for the
JTAG debugger to load U-Boot image into RAM and then resume and
start U-Boot from RAM.
The procedure is as follows:
1) Load u-boot-tpl.bin to 0xe6300000
2) Write magic number 0x1337c0de to 0xe6300020
TPL checks for this particular magic and starts JTAG recovery
if this number is present. This is not present by default.
3) Start U-Boot TPL from 0xe6300000
4) Wait for a message from TPL on UART indicating JTAG boot:
"JTAG boot detected!"
5) Halt the system in JTAG debugger
6) Load U-Boot image (u-boot.img) to 0x4fffffc0
7) Write magic number 0xb33fc0de to 0xe6300024
TPL checks for this particular magic to verify that the U-Boot
image was loaded into DRAM by the JTAG debugger.
8) Resume the system in JTAG debugger
Add and enable TPL on M2 Porter. The TPL must fit into 16 kiB due
to the Gen2 BootROM restriction. The TPL is running from MERAM and
is capable of performing the initial initialization of PFC, Clock,
GPIO, LBSC, DBSC and QSPI NOR. DBSC is responsible for bringing up
the DDR DRAM access. The TPL is capable of loading the next stage,
U-Boot, from either SPI NOR or UART as a fallback. If either does
provide a valid U-Boot uImage, the system stops, which allows the
operator to load U-Boot ie. via JTAG and start it manually.
Pull the SPL code from porter.c into a separate file in
preparation for the addition of system initialization code.
No functional change.
The 'reset' command did not work on Porter because the reset code
was accessing the wrong PMIC address over broken I2C bus driver.
Replace the code with DM-aware code and fix up the PMIC address.
This makes the 'reset' command work again.
Toggle the PHY reset GPIO to bring the ethernet PHY out of reset properly.
NOTE: This should be moved to the SH ethernet driver, but it's quite
late in the cycle, so this is something to be done in 2018.05.
Due to size limitations of the MERAM, switch U-Boot to SPL.
The SPL is loaded by the SPI_LOADER into MERAM and then loads
U-Boot proper into DRAM. This way U-Boot can freely grow in
size in DRAM, as there is plenty of it.
NOTE: To update U-Boot, first install u-boot.img to 0x140000 in SPI NOR,
then use the Minimon to flash u-boot-spl.srec using ls,2,e6304000.
To generate u-boot-spl.srec, use objcopy:
arm-linux-gnueabi-objcopy -O srec spl/u-boot-spl u-boot-spl.srec
Convert the R8A7791 Porter board to DM and DT. This implies mostly
enabling the necessary configuration options and plucking out the
ad-hoc configuration from the board file. Moreover, the pre-reloc
malloc size was increased to allow the clock driver to start up
early without running out of malloc space and the early stack was
moved further up in the DRAM to avoid rewriting U-Boot itself.
Rename this function for consistency with env_get().
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
To common use of rcar-gen2-common directory in the R-Car SoCs, and change from
rcar-gen2-common to rcar-common.
Porter is an entry level development board based on R-Car M2 SoC (R8A7791)
This commit supports the following peripherals:
- SCIF, I2C, Ethernet, QSPI, SD, USB Host
Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com>
