path: root/board/renesas/gose/qos.h
2014-11-10arm: rmobile: Add support gose boardNobuhiro Iwamatsu
The gose board has R8A7793, 1GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF - QSPI - SPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
