The bootparams do not have to be at fixed location, they can be
dynamically mallocated instead. Make it so to get rid of another
fixed assignment.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Biju Das <biju.das.jz@bp.renesas.com>
Cc: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Remove empty board_early_init_f function, since it is disabled
in ebisu and condor board configs.
Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com>
Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Default s_init weak function available, so remove the
s_init empty function.
Move this uncommon header out of the common header.
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
Move this function out of common.h and into a relevant header file.
Add board code for the R8A77980 V3H Condor board.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
