path: root/board/renesas/ap325rxa/Makefile
2016-12-02sh: place board lowlevel_init code in the beginning of .textVladimir Zapolskiy
Reference lowlevel_init of all supported SH2A/SH3/SH4/SH4A boards from a shared linker script, the lowlevel_init function will be called by a relative address. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2008-10-31sh: ap325rxa: Moved ap325rxa board to board/renesasNobuhiro Iwamatsu
