Control macro of mstp is common in R-Car ARM SoC (r8a7790, r8a7791,
r8a7793 and r8a7794). This moves these to arch-rmobile/rcar-mstp.h
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Module control registers of R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and
r8a7794) are same address. This moves these to header file of SoC.
Alt board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
dram_init_banksize instead.
The i2c_init function is no longer necessary.
PowerIC connected to channel 1 of sh-i2c, not channel 2.
Alt board was connected Power IC to channel 1 of sh-i2c. Source code that
controls this is already included, but channel 1 of sh-i2c is not enabled.
This enables channel 1 of sh-i2c, and can use.
Alt board does not use board_late_init function.
This removes this function and define of BOARD_LATE_INIT from config.
Alt board use SCIF2, not SCIF0.
Since board info structure is not still set up, the setting of RAM
address causes illegal access.
Therefore the setting of RAM address is removed.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM.
The default boot address is 0x70000000.
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Rmobile board select menu to rmobile/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="rmobile").
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
The alt board has R8A7794, 1GB DDR3-SDRAM, USB, Ethernet, QSPI,
MMC, SDHI and more.
This commit supports the following functions:
- DDR3-SDRAM
- SCIF
- I2C
- Ethernet
- QSPI
