path: root/board/raspberrypi
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-17efi_loader: round the memory area in efi_add_memory_map()Michael Walle
Virtually all callers of this function do the rounding on their own. Some do it right, some don't. Instead of doing this in each caller, do the rounding in efi_add_memory_map(). Change the size parameter to bytes instead of pages and remove aligning and size calculation in all callers. There is no more need to make the original efi_add_memory_map() (which takes pages as size) available outside the module. Thus rename it to efi_add_memory_map_pg() and make it static to prevent further misuse outside the module. Signed-off-by: Michael Walle <michael@walle.cc> Add missing comma in sunxi_display.c. Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-13rpi: use the newly-added RPI_EFI_NR_SPIN_PAGESKyle Evans
Some systems may use a slightly larger stub to do PSCI for booting the RPi family. The number of pages has been made configurable so that operating systems building U-Boot for use in these kinds of environments can reserve more memory in the EFI memory map. Signed-off-by: Kyle Evans <kevans@FreeBSD.org> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2020-05-13rpi: Kconfig option for initial page reservationKyle Evans
While the nearly-universal default for the Raspberry Pi family is to use spin tables and the spin table implementation provided by the Raspberry Pi Foundation, FreeBSD and others may use a PSCI implementation instead. Accommodate these setups by allowing them to configure for more than one page to be reserved in the initial reservation. The default reservation remains as one page. Signed-off-by: Kyle Evans <kevans@FreeBSD.org> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-12-11rpi: Enable DRAM bank initialization on arm64Matthias Brugger
Up to now we only update the DRAM banks when we are define CONFIG_BCM2711. But our one binary approach uses a config that supports BCM2837 and BCM2711. As a result we only see one gibibyte of RAM on Raspberry Pi 4, even if it has more RAM. Fix this by calling dram_init_banksize. Fixes: 5694090670 ("ARM: defconfig: add unified config for RPi3 and RPi4") Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-12-11rpi: fix dram bank initializationMatthias Brugger
To update the dram bank information from device-tree we use fdtdec_decode_ram_size() which expectes the the size-cells and address-cells to be defined in the memory node. For normal system RAM these values are defined in the root node. When the values differ from the default values defined in the spec, we can end up with wrong RAM bank information. Switch to the "standard" way to update the RAM bank information to avoid this. Fixes: 9de5b89e4c ("rpi4: enable dram bank initialization") Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-12-02common: Move board_get_usable_ram_top() out of common.hSimon Glass
Move this function into init.h which seems to be designed for this sort of thing. Also update the header to declare struct global_data so that it can be included without global_data.h being needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-24ARM: bcm283x: Set memory map at run-timeMatthias Brugger
For bcm283x based on arm64 we also have to change the mm_region. Add assign this in mach_cpu_init() so we can create now one binary for RPi3 and RPi4. Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-11-24rpi: push fw_dtb_pointer in the .data sectionMatthias Brugger
The fw_dtb_pointer was defined in the assembly code, which makes him live in section .text_rest Put that's not necessary, we can push the variable in the .data section. This will prevent relocation errors like: board/raspberrypi/rpi/rpi.c:317:(.text.board_get_usable_ram_top+0x8): relocation truncated to fit: R_AARCH64_LDST64_ABS_LO12_NC against symbol `fw_dtb_pointer' defined in .text section in board/raspberrypi/rpi/built-in.o Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-10-01rpi4: enable dram bank initializationMatthias Brugger
When booting through the efi stub, the memory map get's created by reading the dram bank information. Depending on the version of the RPi4 this information changes. Read the device tree to initialize the dram bank data structure. This way the kernel is able to access the whole range of available memory. Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-09-06RPI: Add memory map for bcm2711Andrei Gherzan
Define the memory map for the BCM2711 based on the dt configuration available in the Raspberry Pi kernel fork. Signed-off-by: Andrei Gherzan <andrei@balena.io> [mb: BCM2838 -> BCM2711] Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-09-06RPI: Add entry for Raspberry Pi 4 model BAndrei Gherzan
The Raspebrry Pi 4 uses the new revision code scheme as documented by the foundation. This change adds an entry for this board as well. Signed-off-by: Andrei Gherzan <andrei@balena.io> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-03-29RPi: Add mbrugger as board maintainerMatthias Brugger
I took over maintainership from Alex Graf with commit 3157bbfa18 ("rpi: Make Matthias maintainer") But I forgot to update the board maintainer file. This patch adds myself to the game. Signed-off-by: Matthias Brugger <mbrugger@suse.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Alexander Graf <agraf@csgraf.de>
2019-02-15rpi: add Compute Module 3+Jonathan Gray
Add Raspberry Pi Compute Module 3+ to list of models, the revision code is 0x10 according to the list on raspberrypi.org. v2: Use the same dtb name as CM3 as CM3+ is a drop in replacement for CM3. Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2018-12-03rpi: add 3 Model A+Jonathan Gray
Add Raspberry Pi 3 Model A+ to list of models, the revision code is 0xE according to the list on raspberrypi.org. Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-03rpi: add URL of official revision code listJonathan Gray
Replace various third party lists of Raspberry Pi revision codes in a comment with the list on raspberrypi.org. Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-06rpi: Complete table of models with new revision code schemeJonathan Gray
In the model table for the new revision code encoding documented in https://www.raspberrypi.org/documentation/hardware/raspberrypi/revision-codes/README.md add the entries for old models with the new scheme and add CM3 which only appears in the new scheme. A device tree for CM3 is not currently upstreamed in linux. When that happens the name will likely have to be adjusted in the table. Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-05rpi: Add identifier for the new RPi3 B+Alexander Graf
The Raspberr Pi Foundation released a new RPi3 version which we want to detect as well, so we can enable ethernet on it and know the correct device tree file name. Add an identifier for it. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-02-15RPi: Add myself as board maintainerAlexander Graf
Commit 958d55f26ce ("MAINTAINERS: Take over BCM2835 maintainership") put me in as maintainer for the RPi soc, but forgot to update the board MAINTAINERS file. Add me there too. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28rpi: Remove runtime disabling support for serialAlexander Graf
We are switching to a model where our board file can directly fail probing of serial devices when they're not usable, so remove the current runtime hack we have. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28bcm283x: Add pinctrl driverAlexander Graf
The bcm283x family of SoCs have a GPIO controller that also acts as pinctrl controller. This patch introduces a new pinctrl driver that can actually properly mux devices into their device tree defined pin states and is now the primary owner of the gpio device. The previous GPIO driver gets moved into a subdevice of the pinctrl driver, bound to the same OF node. That way whenever a device asks for pinctrl support, it gets it automatically from the pinctrl driver and GPIO support is still available in the normal command line phase. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-04add support for Raspberry Pi Zero WDmitry Korunov
Signed-off-by: Dmitry Korunov <dessel.k@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-08MAINTAINERS: drop bcm283x/rpi maintainershipStephen Warren
It's been a while since I've touched U-Boot on the Raspberry Pi and other things have been taking my time. Drop my maintainership for this port. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2017-05-09Allow boards to initialize the DT at runtime.Alex Deymo
In some boards like the Raspberry Pi the initial bootloader will pass a DT to the kernel. When using U-Boot as such kernel, the board code in U-Boot should be able to provide U-Boot with this, already assembled device tree blob. This patch introduces a new config option CONFIG_OF_BOARD to use instead of CONFIG_OF_EMBED or CONFIG_OF_SEPARATE which will initialize the DT from a board-specific funtion instead of bundling one with U-Boot or as a separated file. This allows boards like the Raspberry Pi to reuse the device tree passed from the bootcode.bin and start.elf firmware files, including the run-time selected device tree overlays. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09bcm2835_wdt: support for the BCM2835/2836 watchdogPaolo Pisati
Signed-off-by: Paolo Pisati <p.pisati@gmail.com>
2017-05-09arm: rpi: Add a TODO to move all messages into the msg handlerSimon Glass
The board code should all move into msg.c for consistency. Add a TODO for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09dm: mmc: rpi: Convert Raspberry Pi to driver model for MMCSimon Glass
Convert the bcm2835 SDHCI driver over to support CONFIG_DM_MMC and move all boards over. There is no need to keep the old code since there are no other users. Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09arm: rpi: Add a function to obtain the MMC clockSimon Glass
Move this code into the new message handler file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09arm: rpi: Add a file to handle messagesSimon Glass
The bcm283x chips provide a way for the ARM core to communicate with the graphics processor, which is in charge of many things. This is handled by way of a message prototcol. At present the code for sending message (and receiving a reply) is spread around U-Boot, primarily in the board file. This means that sending a message from a driver requires duplicating the code. Create a new message implementation with a function to support powering on a subsystem as a starting point. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-24rpi: Fix device tree path on ARM64Tuomas Tynkkynen
The directory structure of device tree files produced by the kernel's 'make dtbs_install' is different on ARM64, the RPi3 device tree file is in a 'broadcom' subdirectory there. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-11-28bcm2835: Reserve the spin table in efi memory mapAlexander Graf
Firmware provides a spin table on the raspberry pi. This table shouldn't get overwritten by payloads, so we need to mark it as reserved. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-11-28ARM: bcm283x: use OF_CONTROL for bcm283xFabian Vogt
This patch removes use of U_BOOT_DEVICE in board/raspberrypi/rpi/rpi.c, enables OF_CONTROL in the config and adjusts the rpi_*defconfig configs. Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-28board: rpi: move uart deactivation to board_initFabian Vogt
When using OF_CONTROL, the disabled value of the mini UART platdata gets reset after board_early_init_f. So move detection and disabling to board_init and remove board_early_init_f. This uses the first device using the mini uart driver, as this method works reliably with different device trees or even no device tree at all. Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-21rpi: passthrough of the firmware provided FDT blobCédric Schieli
Raspberry firmware used to pass a FDT blob at a fixed address (0x100), but this is not true anymore. The address now depends on both the memory size and the blob size [1]. If one wants to passthrough this FDT blob to the kernel, the most reliable way is to save its address from the r2/x0 register in the U-Boot entry point and expose it in a environment variable for further processing. This patch just does this: - save the provided address in the global variable fw_dtb_pointer - expose it in ${fdt_addr} if it points to a a valid FDT blob There are many different ways to use it. One can, for example, use the following script which will extract from the tree the command line built by the firmware, then hand over the blob to a previously loaded kernel: fdt addr ${fdt_addr} fdt get value bootargs /chosen bootargs bootz ${kernel_addr_r} - ${fdt_addr} Alternatively, users relying on sysboot/pxe can simply omit any FDT statement in their extlinux.conf file, U-Boot will automagically pick ${fdt_addr} and pass it to the kernel. [1] https://www.raspberrypi.org/forums//viewtopic.php?f=107&t=134018 Signed-off-by: Cédric Schieli <cschieli@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-15armv8: mmu: Add support of non-identical mappingYork Sun
Introduce virtual and physical addresses in the mapping table. This change have no impact on existing boards because they all use idential mapping. Signed-off-by: York Sun <york.sun@nxp.com>
2016-04-11rpi: remove redundant board filesStephen Warren
Now that rpi_*defconfig and Kconfig (rather than the config header file) provide the identity of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header. The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway. While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too. Partially-suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11ARM: add Raspberry Pi 3 64-bit configStephen Warren
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU before entering the kernel (a/k/a U-Boot for us). This feature is not currently supported by the VC FW when booting in 64-bit mode. However, this feature will likely appear in the near future, and this U-Boot port assumes that such a feature is in place. Without that feature, or a temporary workaround described below, U-Boot will not boot. Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can be used drectly as kernel7.img, in the same way as any other RPi port. The following config.txt is required: # Fix mini UART input frequency, and setup/enable up the UART. # Without this option, U-Boot will not boot, even if you don't care # about the serial console. This option will always be required for # all RPi3 use-cases, unless the PL011 UART is used, which is not # yet supported by rpi_3* builds of U-Boot. enable_uart=1 # Boot in AArch64 (64-bit) mode. # It is possible that a future VC FW will remove the need for this # option, instead auto-setting 32-/64-bit mode based on the "kernel" # filename present on the SD card. arm_control=0x200 Prior to the VC FW providing the ARM boot stub, you can use the following steps to build an equivalent stub into the U-Boot binary: git clone https://github.com/swarren/rpi-3-aarch64-demo.git \ ../rpi-3-aarch64-demo (cd ../rpi-3-aarch64-demo && ./build.sh) Build U-Boot for rpi_3 in the usual way cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed Use u-boot.bin.stubbed as kernel7.img on the Pi SD card. In this case, the following additional entries are required in config.txt: # Tell the FW to load the kernel image at address 0, the reset vector. kernel_old=1 Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01rpi: BCM2837 and Raspberry Pi 3 32-bit supportStephen Warren
The Raspberry Pi 3 contains a BCM2837 SoC. The BCM2837 is a BCM2836 with the CPU complex swapped out for a quad-core ARMv8. This can operate in 32- or 64-bit mode. 32-bit mode is the current default selected by the VideoCore firmware on the Raspberry Pi 3. This patch adds a 32-bit port of U-Boot for the Raspberry Pi 3. >From U-Boot's perspective, the only delta between the RPi 2 and RPi 3 is a change in usage of the SoC UARTs. On all previous Pis, the PL011 was the only UART in use. The Raspberry Pi 3 adds a Bluetooth module which uses a UART to connect to the SoC. By default, the PL011 is used for this purpose since it has larger FIFOs than the other "mini" UART. However, this can be configured via the VideoCore firmware's config.txt file. This patch hard-codes use of the mini UART in the RPi 3 port. If your system uses the PL011 UART for the console even on the RPi 3, please use the RPi 2 U-Boot port instead. A future change might determine which UART to use at run-time, thus allowing the RPi 2 and RPi 3 (32-bit) ports to be squashed together. The mini UART has some limitations. One externally visible issue in the BCM2837 integration is that the UART divides the SoC's "core clock" to generate the baud rate. The core clock is typically variable, and under control of the VideoCore firmware for thermal management reasons. If the VC FW does modify the core clock rate, UART communication will be corrupted since the baud rate will vary from the expected value. This was not an issue for the PL011 UART, since it is fed by a fixed 3MHz clock. To work around this, the VideoCore firmware can be told not to modify the SoC core clock. However, the only way this can happen and be thermally safe is to limit the core clock to a low/minimum frequency. This leaves performance on the table for use-cases that don't care about a UART console. Consequently, use of the mini UART console must be explicitly requested by entering the following line into config.txt: enable_uart=1 A recent version of the VC firmware is required to ensure that the mini UART is fully and correctly initialized by the VC FW; at least firmware.git 046effa13ebc "firmware: arm_loader: emmc clock depends on core clock See: https://github.com/raspberrypi/firmware/issues/572". Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01rpi: add Raspberry Pi 3 board IDStephen Warren
This allows U-Boot to known the name of the board. The existing rpi_2_defconfig can operate correctly on the Raspberry Pi 3 in 32-bit mode /if/ you have configured the firmware to use the PL011 UART as the console UART (the default is the mini UART). This requires two things: a) config.txt should contain dtoverlay=pi3-miniuart-bt b) You should run the following to tell the VC FW to process DT when booting, and copy u-boot.bin.img (rather than u-boot.bin) to the SD card as the kernel image: path/to/kernel/scripts/mkknlimg --dtok u-boot.bin u-boot.bin.img This works as of firmware.git commit 046effa13ebc "firmware: arm_loader: emmc clock depends on core clock See: https://github.com/raspberrypi/firmware/issues/572". Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01rpi: use constant "unknown board" DT filenameStephen Warren
To simplify support for new SoCs, just use a constant filename for the unknown case. In practice this case shouldn't be hit anyway, so the filename isn't relevant, and certainly doesn't need to differentiate between SoCs. If a user has an as-yet-unknown board, they can override this value in the environment anyway. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
