path: root/board/raspberrypi
2015-12-05rpi: add support for Raspberry Pi ZeroStephen Warren
For U-Boot's purposes, at present all we care about is ensuring there's a model table entry. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-12-05rpi: fix revision scheme parsingStephen Warren
The RPi has two different schemes for encoding board revision values. When adding RPi 2 support, I thought that the conflicting type field values were to be interpreted based on bcm2835-vs-bcm2836. In fact, the scheme bit determines the encoding. The RPi Zero uses the bcm2835 yet uses the new encoding scheme. Fix the code to cater for this correctly. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-12-05rpi: get rid of BCM2835_BOARD_REV_* macrosStephen Warren
There are two numbering schemes for the RPi revision values; old and new scheme. The values within each scheme overlap. Hence, it doesn't make sense to have absolute/global names for the revision IDs. Get rid of the names and just use the raw revision/type values to set up the array of per-revision data. This change makes most sense when coupled with the next change. However, it's split out so that the mechanical cut/paste is separate from the logic changes for easier review and problem bisection. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-10-24ARM: rpi: Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG supportGuillaume GARDET
Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG support and enable it to set 'board_rev' and 'board_name' envs. 'board_rev' can be used in scripts to determine what board we are running on and 'board_name' for pretty printing. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-10-19ARM: rpi: add another revision of Raspberry Pi A+Lubomir Rintel
Seen this one in the wild. Is labelled "Raspberry Pi Model A+ V1.1, (C) Raspberry Pi 2014". A standard A+ board, much like the one with version 0x12, didn't notice any differencies. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-12ARM: bcm283x: Allocate all mailbox buffers cacheline alignedAlexander Stein
The mailbox buffer is required to be at least 16 bytes aligned, but for cache invalidation and/or flush it needs to be cacheline aligned. Use ALLOC_CACHE_ALIGN_BUFFER for all mailbox buffer allocations. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2015-04-13ARM: rpi: add a couple more revision IDsStephen Warren
According to Gordon Henderson's WiringPi library, there are some more Pi revision IDs out there. Add support for them. http://git.drogon.net/?p=wiringPi;a=blob_plain;f=wiringPi/wiringPi.c;hb=5edd177112c99416f68ba3e8c6c4db6ed942e796 At least ID 0x13 is out in the wild: Reported-by: Chee-Yang Chau <cychau@gmail.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-03-28ARM: bcm283x: merge BCM2835/BCM2836 directories into mach-bcm283xMasahiro Yamada
BCM2835 (used on Raspberry Pi) and BCM2836 (used on Raspberry Pi 2) are similar enough. One of the biggest differences is the ARM processor. It is reasonable to collect the source files into a single place, arch/arm/mach-bcm283x/. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-03-24ARM: rpi: fix RPi1 board rev detection for warranty bitStephen Warren
Apparently the firmware's board rev response includes both the board revision and some other data even on the RPi1. In particular, the "warranty bit" is bit 24. We need to mask that out when looking up the board ID. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21rpi: add support for Raspberry Pi 2 model BStephen Warren
USB doesn't seem to work yet; the controller detects the on-board Hub/ Ethernet device but can't read the descriptors from it. I haven't investigated yet. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21bcm2835/rpi: add SPDX license tags for some filesStephen Warren
2015-02-10lcd: dt: extract simplefb supportNikita Kiryanov
We now have api functions that can support compiling simplefb code as its own module. Since this code is not part of the display functionality, extract it to its own file. Raspberry Pi is updated to accommodate the changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2014-12-29ARM: rpi: consolidate board rev error checkingStephen Warren
Create a fake model table entry with default values, so we can error check the board rev value once when querying it from the firmware, rather than error-checking for invalid board rev values every time the model table is used. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-29ARM: rpi: support model A+Stephen Warren
Add a board rev entry for the new model A+, and augment the board rev error handling code to be a bit more verbose. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-29ARM: rpi: only set usbethaddr on relevant systemsStephen Warren
Model A and CM RPis don't have an on-board USB Ethernet device. Hence, there's no point setting $usbethaddr based on the device fuses. Use the model detection code to gate this. Note that the fuses are actually programmed even on those devices though. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-11dm: rpi: Move serial to driver modelSimon Glass
Adjust the configuration to use the driver model version of the pl01x serial driver. Add the required platform data. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: rpi_b: detect board revisionStephen Warren
Detect the board revision early during boot, and print the decoded model name. Eventually, this information can be used for tasks such as: - Allowing/preventing USB device mode; some models have a USB device on- board so only host mode makes sense. Others connect the SoC directly to the USB connector, so device-mode might make sense. - The on-board USB hub/Ethernet requires different GPIOs to enable it, although luckily the default appears to be fine so far. - The compute module contains an on-board eMMC device, so we could store the environment there. Other models use an SD card and so don't support saving the environment (unless we store it in a file on the FAT boot partition...) Set $fdtfile based on this information. At present, the mainline Linux kernel doesn't contain a separate DTB for most models, but I hope that will change soon. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-26Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-10-22ARM: rpi_b: query internal MAC address from firmwareStephen Warren
The built-in SMSC 95xx chip doesn't know its own MAC address. Instead, we must query it from the VC firmware; it's probably encoded in fuses on the BCM2835. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-10-22dm: rpi: Convert GPIO driver to driver modelSimon Glass
Convert the BCM2835 GPIO driver to use driver model, and switch over Raspberry Pi to use this, since it is the only board. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2014-07-18board: rpi_b: include mmc header and fix prototypeJeroen Hofstee
While at it add fdt_support.h as well. cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-01-20ARM: rpi_b: power on SDHCI and USB HW modulesStephen Warren
Send RPC commands to the VideoCore to turn on the SDHCI and USB modules. For SDHCI this isn't needed in practice, since the firmware already turned on the power in order to load U-Boot. However, it's best to be explicit. For USB, this is necessary, since the module isn't powered otherwise. This will allow the kernel USB driver to work. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-06-05ARM: bcm2835: add simplefb DT node during bootz/mStephen Warren
Add a DT simple-framebuffer node to DT when booting the Linux kernel. This will allow the kernel to inherit the framebuffer configuration from U-Boot, and display a graphical boot console, and even run a full SW- rendered X server. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-03-20ARM: rpi_b: enable SD controller, add related env/cmdsStephen Warren
Enable the SD controller driver for the Raspberry Pi. Enable a number of useful MMC, partition, and filesystem-related commands. Set up the environment to provide standard locations for loading a kernel, DTB, etc. Provide a boot command that loads and executes boot.scr.uimg from the SD card; this is written considering future extensibilty to USB storage. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-03-20ARM: rpi_b: use bcm2835 mbox driver to get memory sizeStephen Warren
The firmware running on the bcm2835 SoC's VideoCore CPU determines how much of the system RAM is available for use by the ARM CPU. Previously, U-Boot assumed that only 128MB was available, since this was the smallest value configured by any public firmware. However, we can now query the actual value at run-time from the firmware using the mbox property protocol. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2012-09-01ARM: add Raspberry Pi model B board, using BCM2835 SoCStephen Warren
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM, contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors. For more details, see http://www.raspberrypi.org/. Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack relocation to top of RAM) extracted from work by: Oleksandr Tymoshenko <gonzo@bluezbox.com>. GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Tom Rini <trini@ti.com>
