path: root/board/r360mpi/r360mpi.c
2015-01-05mpc8xx: remove R360MPI board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-07-16Incorporate Patch by Lutz Dennig, 15 Jul 2003.wdenk
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-04-20Compile fixeswdenk
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-12* Patch by Lutz Dennig, 10 Apr 2003:LABEL_2003_04_15_1900wdenk
Update for R360MPI board * Add new meaning to "autostart" environment variable: If set to "no", a standalone image passed to the "bootm" command will be copied to the load address (and eventually uncompressed), but NOT be started. This can be used to load and uncompress arbitrary data. * Set max brightness for MN11236 displays on TRAB board
