path: root/board/r2dplus
2008-09-02Moved initialization of RTL8139 Ethernet controller to board_eth_init()Ben Warren
Affected boards: hidden_dragon MPC8544DS MPC8610HPCN R2DPLUS TB0229 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07sh: Cleanup source code of R2DPlusNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2008-03-28sh: Add support Renesas Solutions R2D plus boardNobuhiro Iwamatsu
R2D plus is SH reference board used with SH7751R. This board has 266Mhz CPU, 64MB SDRAM, Cardbus, CF interface, one PCI bus, VGA, and two Ethernet controller. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
