path: root/board/quipos
2017-05-15omap3: Drop CONFIG_OMAP3_EVM, switch to CONFIG_TARGET_OMAP3_EVM when neededTom Rini
We make use of CONFIG_OMAP3_EVM today to know when to do a specific tweak in MUSB. This can be tested on via CONFIG_TARGET_OMAP3_EVM instead, so switch there so we can drop the now unused symbol CONFIG_OMAP3_EVM. In investigating what to do about the symbol usage we see that the cairo board defines the same function, but never called it (as it does not define CONFIG_OMAP3_EVM) and was just returning anyhow, so drop that function from that board. Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-28arm: Note vendor-required status of certain MACH_TYPE valuesTom Rini
In the cases of some boards, a MACH_TYPE number is used which is either not registered upstream or worse (for functionality) is re-using the number of a different (or reference) platform instead. Make sure we have a comment in these cases. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Walter Schweizer <swwa@users.sourceforge.net> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: Various: Future-proof serial platdataAdam Ford
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes. Tested on the Logic PD Torpedo + Wireless. I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf. Signed-off-by: Adam Ford <aford173@gmail.com> V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c V4: Fix subject heading V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default. V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-07cairo: add missing MAINTAINERS fileAlbert ARIBAUD \(3ADEV\)
This removes the following two warnings from buildman: WARNING: no status info for 'cairo' WARNING: no maintainers for 'cairo' Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-03-05omap3: add support for QUIPOS Cairo board.Albert ARIBAUD \(3ADEV\)
This patch extends OMAP3 support for AM/DM37xx and introduces the AM3703-based Quipos Cairo board. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr> Reviewed-by: Simon Glass <sjg@chromium.org>
