path: root/board/quipos/cairo/cairo.c
2016-03-14ARM: Various: Future-proof serial platdataAdam Ford
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes. Tested on the Logic PD Torpedo + Wireless. I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf. Signed-off-by: Adam Ford <aford173@gmail.com> V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c V4: Fix subject heading V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default. V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05omap3: add support for QUIPOS Cairo board.Albert ARIBAUD \(3ADEV\)
This patch extends OMAP3 support for AM/DM37xx and introduces the AM3703-based Quipos Cairo board. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr> Reviewed-by: Simon Glass <sjg@chromium.org>
