path: root/board/quantum
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
