path: root/board/quantum/u-boot.lds.debug
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
