path: root/board/qualcomm
2020-01-30MAINTAINERS: board: qcom: db820c: update emailJorge Ramirez-Ortiz
Signed-off-by: Jorge Ramirez-Ortiz <jorge@foundries.io>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-14MAINTAINERS: change Ramon Fried email addressRamon Fried
Change my email address, too many mails gets to my private mail, created specific email account just for developmement. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-12-03MAINTAINERS: board: qcom: db820c: update email.Jorge Ramirez-Ortiz
Update email address Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-09-30db410c: automatically launch fastbootRamon Fried
If during boot the key-vol-down press is detected we'll fall back to fastboot. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-09-30db410c: serial# env using msm board serialRamon Fried
The serial# environment variable needs to be defined so it will be used by fastboot as serial for the endpoint descriptor. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-09-30ehci: Replace board_prepare_usb with board_usb_initRamon Fried
Use standard board_usb_init() instead of the specific board_prepare_usb. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13db410: alter WLAN/BT MAC address fixupRamon Fried
Change the way MAC address fixup is done: 1. Stop using LK handed device-tree and calculate the MAC address our own. 2. Allow overriding the generated MACS with environment variables: "wlanaddr" and "btaddr". Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-10db410c: Fixup DRAMRamon Fried
Call the MSM DRAM detection and fixup function to support dynamic detection of onboard memory. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-07-25efi_loader: Rename sections to allow for implicit dataAlexander Graf
Some times gcc may generate data that is then used within code that may be part of an efi runtime section. That data could be jump tables, constants or strings. In order to make sure we catch these, we need to ensure that gcc emits them into a section that we can relocate together with all the other efi runtime bits. This only works if the -ffunction-sections and -fdata-sections flags are passed and the efi runtime functions are in a section that starts with ".text". Up to now we had all efi runtime bits in sections that did not interfere with the normal section naming scheme, but this forces us to do so. Hence we need to move the efi_loader text/data/rodata sections before the global *(.text*) catch-all section. With this patch in place, we should hopefully have an easier time to extend the efi runtime functionality in the future. Signed-off-by: Alexander Graf <agraf@suse.de> [agraf: Fix x86_64 breakage]
2018-06-04MAINTAINERS: Take over DB410c maintainershipRamon Fried
2018-02-04MAINTAINERS: board: qcom: db410c, db820c: update email.Jorge Ramirez-Ortiz
Update email address. Signed-off-by: Jorge Ramirez-Ortiz <jramirez@baylibre.com>
2018-01-15db410c: use the device tree parsed by the lk loader.Jorge Ramirez-Ortiz
We dont need to keep copies of the properties that we are going to fixup since we will be using the dtb provided by the firmware. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db410c: replace reset driver with psciJorge Ramirez-Ortiz
this should be the norm for armv8 platforms. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db410c: update wlan and bt mac addresses from firmwareJorge Ramirez-Ortiz
The firmware that runs before u-boot modifies u-boot's device tree adding the local-mac-address and local-bd-address properties for the compatibles "qcom,wcnss-bt" and "qcom,wcnss-wlan". This commit reads that firmware, retrieves the properties and fixups the device tree that is passed to the kernel before booting. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db820c: stop autoboot when vol- pressedJorge Ramirez-Ortiz
2018-01-15db820c: add qualcomm dragonboard 820C supportJorge Ramirez-Ortiz
This commit adds support for 96Boards Dragonboard820C. The board is based on APQ8086 Qualcomm Soc, complying with the 96Boards specification. Features - 4x Kyro CPU (64 bit) up to 2.15GHz - USB2.0 - USB3.0 - ISP - Qualcomm Hexagon DSP - SD 3.0 (UHS-I) - UFS 2.0 - Qualcomm Adreno 530 GPU - GPS - BT 4.2 - Wi-Fi 2.4GHz, 5GHz (802.11ac) - PCIe 2.0 - MIPI-CSI, MIPI-DSI - I2S U-Boot boots chained from LK (LK implements the fastboot protocol) in 64-bit mode. For detailed build instructions see readme.txt in the board directory. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-09-11MAINTAINERS: board: qcom: db410c: Maintainer changedJorge Ramirez-Ortiz
Replacing original author Mateusz Kulikowski <mateusz.kulikowski@gmail.com> as db410c maintainer Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-06-23board/db410c: add missing linker map entries for efiRob Clark
Otherwise the loaded image would miss the efi_runtime sections, and fall over hard when grub (for example) tried to call runtime services located in this section. Signed-off-by: Rob Clark <robdclark@gmail.com>
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-01board: Add Qualcomm Dragonboard 410C supportMateusz Kulikowski
This commit add support for 96Boards Dragonboard410C. It is board based on APQ8016 Qualcomm SoC, complying with 96boards specification. Features (present out of the box): - 4x Cortex A53 (ARMv8) - 2x USB Host port - 1x USB Device port - 4x LEDs - 1x HDMI connector - 1x uSD connector - 3x buttons (Power, Vol+, Vol-/Reset) - WIFI, Bluetooth with integrated antenna - 8GiB eMMC U-Boot boots chained with fastboot in 64-bit mode. For detailed build instructions see readme.txt in board directory. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Tested-by: Simon Glass <sjg@chromium.org>
