path: root/board/qemu-mips
2008-05-09Mail address change, documentation modifiedVlad Lungu
Signed-off-by: Vlad Lungu <vlad.lungu@windrvier.com>
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-22MIPS: Fix CFG_NO_FLASH supportJean-Christophe PLAGNIOL-VILLARD
- Fix flash_init call when CFG_NO_FLASH is used - Remove no more needed flash.c for qemu-mips Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
