path: root/board/qemu-mips
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-16MIPS: add board qemu-mips64 supportZhi-zhou Zhang
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-10-16MIPS: qemu_mips: move CONFIG_SYS_TEXT_BASE to qemu-mips.hZhi-zhou Zhang
We define CONFIG_SYS_TEXT_BASE in board's specified header file. So config.mk is useless, then remove it. Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2010-09-04MIPS: update the MIPS u-boot.ldsXiangfu Liu
From the document, if set all arguments in "OUTPUT_FORMAT" to "tradbigmips", then even add "-EL" to gcc we still get EB format. pb1x00 is only used in Little-endian, so its default endian should be set to LE. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-08-22qemu-mips: Fix Qemu websiteMichal Simek
Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@petalogix.com> Acked-by: Shinya Kuribayashi <skuribay@pobox.com>
2008-06-05[MIPS] Kill unused <version.h> inclusionsShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-05-30[MIPS] <asm/mipsregs.h>: Update coprocessor register access macrosShinya Kuribayashi
2008-05-09Mail address change, documentation modifiedVlad Lungu
Signed-off-by: Vlad Lungu <vlad.lungu@windrvier.com>
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-22MIPS: Fix CFG_NO_FLASH supportJean-Christophe PLAGNIOL-VILLARD
- Fix flash_init call when CFG_NO_FLASH is used - Remove no more needed flash.c for qemu-mips Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
