path: root/board/qemu-mips/config.mk
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
