The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Move this uncommon header out of the common header.
QCA9563 is CPU used on AP152 board :
Clock speed : 750 MHz ,
Arch : Mips 74Kc,
Eth : SGMII interface,
MIMO config : 3 * 3 450M,
2 * USB 2.0,
Signed-off-by: Rosy Song <rosysong@rosinson.com>
Changes for v2:
- coding style cleanup
- remove ununsed flash chip in defconfig
- enable automatic icache / dcache size in defconfig
Changes for v3:
- add detailed information for qca956x in commit message
Changes for v4:
- remove pre-configured network settings in ap152.h
Changes for v5:
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
In order to add a generic MIPS debug_uart_init call right before the call to
board_early_init_f, we need to remove all calls to debug_uart_init from every
MIPS boards.
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
MIPS boards.
This patch reset the ethernet controller for ap143 board
Signed-off-by: Wills Wang <wills.wang@live.com>
This patch enable network function for ap121 board.
Allow L1 Icache & L1 Dcache line size to be specified separately, since
there's no architectural mandate that they be the same. The
[id]cache_line_size functions are tidied up to take advantage of the
fact that the Kconfig entries are always present to simply check them
for zero rather than needing to #ifdef on their presence.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
[removed CONFIG_SYS_CACHELINE_SIZE in include/configs/pic32mzdask.h]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Move details of the L1 cache line sizes & total sizes into Kconfig,
defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is
introduced to allow platforms to select auto-detection of cache sizes,
and it defaults to being enabled if none of the cache sizes are set by
the configuration (ie. sizes are all the default 0), and code is
adjusted to #ifdef on that rather than on the definition of the sizes
(which will always be defined even if 0).
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board
Kconfig files matching what was present in their config headers. This
will make it cleaner to conditionalise the value for Malta based on 32
vs 64 bit builds.
This patch add board-level code and base DT for AP143.
[updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y]
This patch add board-level code and base DT for AP121.
