path: root/board/purple
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-02Moved initialization of plb2800 Ethernet driver to board_eth_initBen Warren
Affected boards: purple Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-05[MIPS] Update <asm/addrspace.h> headerShinya Kuribayashi
- Fix traditional KSEG names - Replace PHYSADDR with CPHYSADDR Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-06-05[MIPS] Kill unused <version.h> inclusionsShinya Kuribayashi
2008-05-21Fix some whitespace issuesWolfgang Denk
introduced by 53677ef18 "Big white-space cleanup." Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-25[MIPS] Introduce _machine_restartShinya Kuribayashi
Handles machine specific functions by using weak functions. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-17Fix warning: pointer targets in assignment differ in signednessJean-Christophe PLAGNIOL-VILLARD
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Remove duplicated .sdata sectionShinya Kuribayashi
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-12-14Cleanup for CMC_PU2 boardwdenk
2003-05-20Fix SDRAM timing on Purple boardwdenk
2003-04-08Prepare for 0.3.0 releaseU-Boot-0_3_0wdenk
* Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs
