path: root/board/psyent
2006-06-08Update PK1C20 boardScott McNutt
-Update base addresses for standard configuration -Eliminate use of CACHE_BYPASS in board code Patch by Scott McNutt, 08 Jun 2006
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
