path: root/board/psyent/pci5441
2010-04-16nios2: Move individual board linker scripts to common script in cpu tree.Scott McNutt
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-13nios: Move cpu/nios/* to arch/nios/cpu/*Peter Tyser
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
