path: root/board/psyent/common/AMDLV065D.c
2014-08-24nios2: remove obsolete PCI5441 and PK1C20 boardsThomas Chou
2014-06-19Remove nios-32 arch remnantsVasili Galka
nios-32 arch was removed back in 2010 (1117cbf). Code depending on its headers (nios.h, nios-io.h) can't possibly compile since then. As it wasn't fixed till now it is safe to remove. Signed-off-by: Vasili Galka <vvv444@gmail.com>
2010-04-02nios2: Fix outx/writex parameter order in io.hScott McNutt
The outx/writex macros were using writex(addr, val) rather than the standard writex(val, addr), resulting in incompatibilty with architecture independent components. This change set uses standard parameter order. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2006-06-08Update PK1C20 boardScott McNutt
-Update base addresses for standard configuration -Eliminate use of CACHE_BYPASS in board code Patch by Scott McNutt, 08 Jun 2006
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
