path: root/board/prodrive
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-03-30Adds support for the Prodrive PMDRA board, based on a DM6441Pieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-27ppc4xx: Add fdt support to Prodrive alprStefan Roese
Since this board will probably be ported to arch/powerpc in the near future, we add device tree support now. This way we are "ready" for arch/powerpc from now on. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Enable cache support on the ALPR boardPieter Voorthuijsen
2008-01-18ARM: remove useless function board_post_initJean-Christophe PLAGNIOL-VILLARD
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-05Make "file" command happy with some config.mk files; update CHANGELOGWolfgang Denk
2007-04-23Remove BOARDLIBS usage completelyStefan Roese
2007-02-27Minor code cleanup.Wolfgang Denk
2007-02-10[PATCH] Add missing p3mx.h file to repository (ups)Stefan Roese
2007-01-18[PATCH] Add support for Prodrive SCPU (PDNB3 variant) boardStefan Roese
2007-01-18[PATCH] Update Prodrive P3Mx supportStefan Roese
2007-01-06[PATCH] Update ALPR board filesStefan Roese
This update brings the ALPR board support to the newest version. It also fixes a problem with the NAND driver. Signed-off-by: Stefan Roese <sr@denx.de>
2006-12-24Merge with /home/hs/TQ/u-boot-devWolfgang Denk
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-11-30Code cleanup. Update CHANGELOG.Wolfgang Denk
2006-11-29[PATCH] Add support for Prodrive P3M750 & P3M7448 (P3Mx) boardsStefan Roese
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460) and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are quite similar and share the same board directory "prodrive/p3mx" and the same config file "p3mx.h". Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27[PATCH] alpr: remove unused board specific flash driverStefan Roese
2006-11-27[PATCH] Update Prodrive ALPR board support (440GX)Stefan Roese
2006-11-10Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-10-07Update ALPR code (NAND support working now)Stefan Roese
Patch by Stefan Roese, 07 Oct 2006
2006-09-18Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-08-15Add initial support for the ALPR board from ProdriveStefan Roese
NAND needs some additional testing Patch by Heiko Schocher, 15 Aug 2006
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-11-27Changed PPC44x startup message (cpu info, speed...) to common style:Stefan Roese
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005
2005-11-22Add support for Prodrive P3P440 board:Stefan Roese
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005
