path: root/board/prodrive
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03p3mx: Remove serial relocation fixupsPeter Tyser
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-08-19Clean up usage of icache_disable/dcache_disableKumar Gala
There is no point in disabling the icache on 7xx/74xx/86xx parts and not also flushing the icache. All callers of invalidate_l1_instruction_cache() call icache_disable() right after. Make it so icache_disable() calls invalidate_l1_instruction_cache() for us. Also, dcache_disable() already calls dcache_flush() so there is no point in the explicit calls of dcache_flush(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-13Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-13Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-13ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Rework 440GX UIC handlingStefan Roese
This patch reworks the 440GX interrupt handling so that the common 4xx code can be used. The 440GX is an exception to all other 4xx variants by having the cascading interrupt vectors not on UIC0 but on a special UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt handling is simpler without any 440GX special cases. Also some additional cleanup to cpu/ppc4xx/interrupt.c is done. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-03-30Adds support for the Prodrive PMDRA board, based on a DM6441Pieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-27ppc4xx: Add fdt support to Prodrive alprStefan Roese
Since this board will probably be ported to arch/powerpc in the near future, we add device tree support now. This way we are "ready" for arch/powerpc from now on. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Enable cache support on the ALPR boardPieter Voorthuijsen
2008-01-18ARM: remove useless function board_post_initJean-Christophe PLAGNIOL-VILLARD
