The file board/Marvell/include/mv_gen_reg.h is incompatible with
the GPL (see for example the "MARVELL RESERVES THE RIGHT AT ITS SOLE
DISCRETION TO REQUEST THAT THIS CODE BE IMMEDIATELY RETURNED TO
MARVELL" clause). As this cannot be fixed, we remove the file and all
code that depends on it. Fortunately this only affects some very old
boards that have long reached EOL:
CPCI750
DB64360
DB64460
p3m750
p3m7448
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Roger Meier <r.meier@siemens.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
[trini: Fixup common/cmd_io.c]
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460)
and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are
quite similar and share the same board directory "prodrive/p3mx"
and the same config file "p3mx.h".
