This has not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Stefan Roese <sr@denx.de>
[trini: Fixup common/cmd_io.c]
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This patch adds new macros, with frequently used combinations of the
4xx TLB access control and storage attibutes. Additionally the 4xx init.S
files are updated to make use of these new macros. Resulting in easier
to read TLB definitions.
Additionally some init.S files are updated to use the mmu header for the
TLB defines, instead of defining their own macros.
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
Patch by Stefan Roese, 07 Oct 2006
NAND needs some additional testing
Patch by Heiko Schocher, 15 Aug 2006
