path: root/board/prodrive/alpr/alpr.c
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Rework 440GX UIC handlingStefan Roese
This patch reworks the 440GX interrupt handling so that the common 4xx code can be used. The 440GX is an exception to all other 4xx variants by having the cascading interrupt vectors not on UIC0 but on a special UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt handling is simpler without any 440GX special cases. Also some additional cleanup to cpu/ppc4xx/interrupt.c is done. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Add fdt support to Prodrive alprStefan Roese
Since this board will probably be ported to arch/powerpc in the near future, we add device tree support now. This way we are "ready" for arch/powerpc from now on. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-06[PATCH] Update ALPR board filesStefan Roese
This update brings the ALPR board support to the newest version. It also fixes a problem with the NAND driver. Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27[PATCH] Update Prodrive ALPR board support (440GX)Stefan Roese
2006-10-07Update ALPR code (NAND support working now)Stefan Roese
Patch by Stefan Roese, 07 Oct 2006
2006-08-15Add initial support for the ALPR board from ProdriveStefan Roese
NAND needs some additional testing Patch by Heiko Schocher, 15 Aug 2006
