path: root/board/ppmc8260
2007-07-04Remove obsolete mpc824x linker scripts (3 of 4)Grant Likely
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2002-02-15Initial revisionwdenk
2002-02-08Initial revisionwdenk
2002-02-06Initial revisionwdenk
