path: root/board/ppmc8260
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2007-07-04Remove obsolete mpc824x linker scripts (3 of 4)Grant Likely
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2002-02-15Initial revisionwdenk
2002-02-08Initial revisionwdenk
2002-02-06Initial revisionwdenk
