2005-12-12 | (no commit message) | Wolfgang Denk | |
2005-08-31 | Fix problems with ld version 2.16 (dot outside sections problem) | Wolfgang Denk | |
Pointed out by Gerhard Jaeger, 31 Aug 2005; cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html | |||
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-25 | * Header file cleanup for ARMLABEL_2003_06_26_2220 | wdenk | |
* Patch by Murray Jensen, 24 Jun 2003: - make sure to use only U-boot provided header files - fix problems with ".rodata.str1.4" section as used by GCC-3.x | |||
2002-02-06 | Initial revision | wdenk | |
