path: root/board/ppmc7xx
2010-12-1774xx_7xx/mpc86xx/ppmc7xx: Fix do_reset() declarationPeter Tyser
The following commit: commit 882b7d726febe65579d6502c271412ecb05821d7 Author: Mike Frysinger <vapier@gentoo.org> Date: Wed Oct 20 03:41:17 2010 -0400 do_reset: unify duplicate prototypes missed the 74xx_7xx and mpc86xx arches and the ppmc7xx board do_reset() functions which resulted in build errors such as: cpu.c:128: error: conflicting types for 'do_reset' include/command.h:102: error: previous declaration of 'do_reset' was here Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-12-09Remove redundant config.mk filesWolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only redundant entries like PLATFORM_CPPFLAGS += -I$(TOPDIR) or settings of variables that were not used anywhere in the code, like TEXT_END = 0xfe080000 Remove these unnecessary files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Tolunay Orkun <torkun@nextio.com> Cc: Frank Panno <fpanno@delphintech.com> Cc: Heiko Schocher <hs@denx.de> Cc: Brad Kemp <Brad.Kemp@seranoa.com> Acked-by: Heiko Schocher<hs@denx.de>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-12ppmc7xx: Use _start as reset entry pointPeter Tyser
Previously the _warm_start label was used as an entry point. These 2 entry points should be functionally identical after the removal of the BOOTFLAG_WARM define. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2006-07-21Code cleanupWolfgang Denk
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-06-19Add support for wrPPMC7xx/74xx boardsHeiko Schocher
Patch from Richard Danter, 12 Aug 2005
