path: root/board/ppcag
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-10-31ARM: mxs: Configure 2 Gbit DDR2 RAM for BG0900Christoph G. Baumann
The BG0900 module has 2Gbit DRAM module on it, adjust the DataBahn DRAM controller registers so the DRAM module will be correctly recognised. Signed-off-by: Christoph G. Baumann <c.baumann@ppc-ag.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17ARM: mxs: Add PPC-AG BG0900 boardMarek Vasut
This board supports FEC Ethernet, SPI NOR and NAND flash. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Christoph Baumann <c.baumann@ppc-ag.de>
